I am trying to understand what happens when 2 supplies or voltage signals are tied to together as I come across similar situations where a Totem-pole output is also being pulled-up by a weak pull-up. In these cases I am wondering if the signal would conflict and result in an unknown final voltage level. Also, wouldn't the voltage difference between the signals cause unwanted current to flow between them which could be undesirable?
I did a simple simulation in LTSpice where I have 2 DC voltage sources connect in parallel across a load. On the right side are the current measurement results.
The simulation result showed that the voltage across the load is 1.8v. On checking the current in the simulator, I observe that DC supply V1 provides the 0.18mA to the load, but DC supply V2 doesn't. I am wondering - how does the simulator decide which voltage sources provides the 0.18mA to the load (in this case V1 is providing 0.18mA and V2 is 0mA)? Also, shouldn't the current be provided equally by both supplies (V1 providing 0.09mA and V2 providing 0.09mA)?
Thanks for any help in developing a better understanding.
source impedance
-- an ideal voltage source (as in your simulation) always outputs a constant voltage, no matter how much current flows. This is just a heuristic for modeling, an ideal voltage source actually violates the principle ofconservation of energy
and is physically impossible. A practical voltage source like a battery, is equivalent to an ideal voltage source with a resistor in series, representing some equivalent internal resistance. So as more current is drawn, the voltage at the terminals can be less than the ideal voltage source voltage. \$\endgroup\$ – MarkU Dec 23 '15 at 6:50
