I'm connecting Sharp GP2Y1010AU0 to WiFi module ESP8266.
Sharp GP2Y1010AU0 is powered by 5V and ESP8266 by 3.3V. Schematic
I wonder if I need a transistor between Sharp's pin nr 3 and ESP8266? If yes, can it be BC846? And how to connect it (through resistor?)?
I am a beginner in electronics. Excuse my bad English. Defozo
    \$\begingroup\$ Possible duplicate of Is this a 5V to 3.3V level converter? \$\endgroup\$
    – Matt Young
    Dec 23 '15 at 18:56
  • \$\begingroup\$ No, the main question is do I really need to do anything here, since Sharp already has a transistor built-in. \$\endgroup\$
    – Defozo
    Dec 23 '15 at 18:59
You don't have a voltage problem there -- you're feeding the base of a BJT which is a current-mode device, and the pull-up resistor on that line is connected to V-LED, which is also at VCC (3.3V) here. The way they've designed that part, the LED circuit can run on a completely independent power supply.
EDIT: I confused VLED with the base input. You should be fine to run GPIO13 straight to Pin 3, there's no need to source additional current because the LED current is sourced from Pin 1.
