I was disassembling a belt disc sander today and noticed that there was a rather large relay between the switch and the motor. The relay consists mostly of a large copper coil. The motor doesn't have a capacitor and neither does the switch assembly. There are three wires coming out of the motor: red, white and black. All of the wires are of the same size about 14AWG.
When I tried wiring the motor without the relay, I couldn't get it to start without turning the shaft by hand. This would mean that the relay was acting as a starter. I am perplexed because I was under the impression that the only way to start a motor was either by hand or a start capacitor.
Can a relay be used to start a motor, if so, how?
Relay
Motor
5 Answers 5
The relay is likely connected to an auxiliary motor winding that has a different number of turns, a different wire size and resistance compared to the main winding. That would act to start the motor similarly to capacitor starting. There are several possibilities for the motor design details. It is not possible to completely and accurately explain the motor design without close examination of the construction. Photographs might help, but that might still not be enough to determine exactly how the motor works.
Edit Re Photos
Note that the relay has relatively few turns of heavy wire. I believe it is a current relay, wired in series with the main winding. When the motor is first turned on, a high current flows in the main winding through the relay coil causing the relay to connect the auxiliary winding. Since the aux winding has a different inductance and resistance, its current is phase shifted compared to the main current similarly to the phase shift that a capacitor would cause. That defines the direction of rotation and provides starting torque. When the motor approaches full speed, the current drops and the relay disconnects the aux winding.
  • \$\begingroup\$ Added photos. I think you're on to something. \$\endgroup\$
    – user148298
    Dec 24, 2015 at 1:01
  • \$\begingroup\$ Cool! Just curious. Can the relay be replaced with a capacitor and operate correctly? \$\endgroup\$
    – user148298
    Dec 24, 2015 at 1:24
  • \$\begingroup\$ No. The motor has been carefully designed as it is. Some value of capacitor can probably be found to get the motor to operate, but its characteristics would change. I don't know if the aux current leads or lags the main current, but it is likely that it lags and a capacitor would make it lead and reverse the direction of rotation unless the winding connection is reversed. \$\endgroup\$
    – user80875
    Dec 24, 2015 at 1:38
  • \$\begingroup\$ @user80875, No it's actually badly designed. See comment on the latest answer. \$\endgroup\$
    – user148298
    Dec 11, 2023 at 21:53
When you bypassed the relay, was the wire a sufficient size to handle the current needed by the motor? The point of the relay is so that the large amount of current needed by the motor doesn't all have to go through the switch. A smaller, "signal" current can go through the switch, which actuates the relay which connects the much bigger wires that power the motor. If you bypassed the relay and used the smaller switch wires, they may be too small to power the motor. This may be especially true if it requires a large spike in power to get started (which is why they use start capacitors). Did you notice the wires getting hot when it was running?
  • \$\begingroup\$ This was a small motor. It's less than 1HP and looks like a washing machine motor. It has three wires of about 14 gauge: red, white, black. \$\endgroup\$
    – user148298
    Dec 24, 2015 at 0:43
You might posted name plate details of this motor. From there you may find what kind of motor is that. From your information i guess its split-phase single phase induction motor.
In split phase induction motor, there are two windings
        1. Starting winding
              Fewer Turns with Lower Inductance and Higher Resistance.
        2. Main (or) Running Winding
 More no of turns with low Resistance and High Inductance
Here starting winding takes part while starting only, (up to 75-80% of rated speed) after attained this speed starting winding will be disconnected by centrifugal switch. Here instead of centrifugal switch the relay might be used.
The relay in question picks up on the starting current of the run winding, thus closing the normally open contact and switching the live to the start winding (in series withe the 100mF cap). Once start current reduces the relay should drop off.
Should is the key to a possible failure. The scheppach spares list call it a stop relay, I think the translation should have been start relay. The relay requires gravity to reset and you will find the relay requires "up" orientation. I have dismantled the relay and found the reset spring strength almost inconsequential. Also the contact strip was free from the armature, a possible fault which would leave the start winding in circuit and burn it out; as has happened with me.
  • \$\begingroup\$ Bingo! It works like a clothes dryer where a momentary switch supplied current to the coil causing it to jolt the motor to start by exciting the start winding. A dryer, however, has a mechanism to automatically disengage the starting coil such as centrifugal switch. The belt disc sanders relay resets purely by gravity, which poses a serious fire hazard if oriented sideways, as it makes some sanding operations easier. Manufacturers recall them for this flaw. It's also why I initially wanted to switch it to a capacitor start motor or add a centrifugal switch. \$\endgroup\$
    – user148298
    Dec 11, 2023 at 21:52
Indeed I think the outer core index has to link to the central wire in the equation x=d*tf/x^2 in order to attain the perfect equilibrium of 12 degrees otherwise the auxiliary motor won’t start and the relay will combust.
