This question already has an answer here:
I have watched video on youtube when a man exhibits conductivity through his body. But how much current can a human conducts safely? Is there any trick?
I have heard from a man who said that " I'd like to see him connect one wire to his left foot and the other to his right arm. It'll make current pass through his heart. Just a thousandth of an amp passing through any human being's heart can kill them."
How true is that?
marked as duplicate by Andy aka, PeterJ, Daniel Grillo, Olin Lathrop, MarkU Dec 24 '15 at 22:21
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ Not as true as if you go from right foot to left arm. \$\endgroup\$ – EM Fields Dec 24 '15 at 14:53
30 mA is enough to kill with skin contact, touching a live wire, for example.
Avoid the man who said that.
  • \$\begingroup\$ How about the video? \$\endgroup\$ – Rayan Ahmed Dec 24 '15 at 10:44
There probably is a trick. For this video they changed the frequency of the AC voltage to some value for the heart being unsusceptible to ventricular fibrillation. For 100 kHz or greater this is proven. With even higher frequencies the current will only flow on the surface of the body.
    \$\begingroup\$ Do you know that there's a frequency for which the heart is unsusceptible to ventricular fibrillation? If not, I suggest deleting the answer. \$\endgroup\$ – Scott Seidman Dec 24 '15 at 13:45
    \$\begingroup\$ 100 kHz and above are used in surgery. See electrocautery and electrosurgery. \$\endgroup\$ – Ariser Dec 26 '15 at 12:36
