I'm using Arduino Nano and ESP8266.
When I setup like the picture and connect Arduino Nano to PC by USB:
The ESP8266 properly works. (Arduino Nano is just used as a bridge)
I print and read from serial with a C# program, it correctly works.
What I send from C# program:
AT+CWJAP="APN", "Pass"
The message from ESP:
OK
But, when I change the setup as follows:
- Green wire (green wire on picture) to Arduino Digital2 pin
- Red wire (red wire on picture) to Arduino Digital3 pin
- Use Arduino code to read/write serial, instead of C# program
- Create a software serial from code (esp8266 = SoftwareSerial(2, 3))
What I send from SoftwareSerial:
ERROR
Do you have any ideas? Why isn't the result on SoftwareSerial identical to Serial?
