I am implementing a Linear Feedback Shift Register (LFSR) in Pspice A/D with a new logic family. Anyways, to initiate the random number generation I am required to feed in some value to the circuit, to be specific, the output of all the D-latches can not be zero initially so I am trying to make the output of any D-latch '1' initially. It should be done such that after the initialization the circuit works by itself. I tried using a fixed voltage source but that does not work, quite obviously. Please suggest anything you may find applicable to this.
Below is the circuit I am trying to make:
And just in case it may help, I am trying to get results like these:
I would use the ".ic" (initial condition) directive.
Name any node (or find a node name) and then add the directive .ic V(nodename)=required voltageV
In this case, SPICE may struggle without an initial condition for both XOR inputs. I would probably set initial conditions for every flip-flop in this situation.
Update: where to add ic directive.
I would put the directive at the top level node to start with.
| improve this answer | |
  • \$\begingroup\$ If i am making use of subcircuits here, where exactly should i point the .ic command \$\endgroup\$ – abhishek tyagi Dec 26 '15 at 19:33
