I am studying Digital Principles and Applications from Malvino and Leach. I have a doubt in the demultiplexer section. This is the image of a 1 to 16 demux. I understand how it works.
So, if ABCD = 0000 and STROBE = L and DATA = H, then Y0 will be active and it should be H, while rest all inputs would be L. Also, if DATA = L and STROBE = L then all the outputs Y0 through Y15 should be L. But when we try to implement a demultiplexer using a TTL 74154, this is the truth table that is given in the book:
IC 74154 truth table
Here, G1 = STROBE; G2 = DATA and outputs are Y0, Y1, Y2 etc.
Why are the outputs inverted? Is the hardware implementation circuit different than the one explained in theory?
74154 is a TTL circuit, and TTL was designed to make the best use of non-ideal transistors. In the processes of the time, bipolar NPN transistors were fastest, so all TTL circuits were designed around those.
If you have some experience using BJTs you will know that NPN transistors are best used to pull a signal to 0V (common emitter, with the output connected to the collector) and quite weak at pulling a signal high. (Common collector, with the signal connected to the emitter, which remains at 0.7V lower than the base voltage, and therefore considerably below the supply rail.
So TTL circuitry adopted asymmetric logic levels, where '0' was guaranteed to be below 0.8V, and '1' was guaranteed to be above 2.4V, less than half the nominal 5V supply rail.
Likewise a TTL output was guaranteed to sink 16mA (for the 74 series, 8mA for 74LS, other families had their own IOL ratings) but only source 0.4 mA.
This carried through to the input current requirements : you could pull an input high with very little current (40uA), but it took 1.6mA to pull an input low (0.4mA for the later 74LS).
And this carried through to the way the logic was used, and designed with. Inputs were pulled high by default, and only pulled low when necessary, to save power. So you can use a 47 kilohm resistor to pull up ( drops 1.88V at 40 uA) and a switch to pull down - and that practice is still often seen today, in active-low reset circuits, though the symmetry of CMOS makes it unnecessary.
High speed signals were usually active low, for much the same reason. And that's what is going on with the 74154...
It is counterintuitive yes, but it is a well-established convention that the sort of devices that this part will be controlling will have active-low enable inputs.
This all has to do with the actual ic design. So theory will cover only the theory which explains the basic functionality of the working of a demultiplexor.
The actual implementation of the chosen ic has active low outputs. So they are inverted a explained in the theory.
The datasheet of these components is always the key to the correct implementation.
