I work in a project using Allwinner a10 CPU and eagle software i did't find the library I already tried to searched in google and github many time for Allwinner a10 library for eagle software but I did't find any thing where i can find this library ?
    \$\begingroup\$ Why not make the part yourself using the datasheet? \$\endgroup\$ Commented Dec 27, 2015 at 18:50
I couldn't find it either, but if you manage to find an Eagle project which has the part you want then you can export it to a library.
Here's an open-source project that includes the A10 CPU:-
A10-OLinuXino-LIME
As Bruce said you can get it from an existing Eagle file like the one in A10 OLinuXino project.
You can then either extract the lbr using exp-lbr.ulp or you can copy it using the GROUP and COPY commands in the OLinuXino schematic and then PASTE command in your schematic.
You can get it from here as well http://wp.me/p2D6cb-Tz
