I have developed an application that is able to:
1. get and store 8 input values (8 characters)
2. swap upper to lower (or vice versa) case only the first char
3. output the eight characters
E.g.: The input string is "hello this is" the application should:
- get "h" from
user_w_write_8_data
, swap "h" into "H" and store "H" intotmp_1
- get "e" from
user_w_write_8_data
and store it intotmp_2
- get "l" from
user_w_write_8_data
and store it intotmp_3
- get "l" from
user_w_write_8_data
and store it intotmp_4
- get "o" from
user_w_write_8_data
and store it intotmp_5
- get " " from
user_w_write_8_data
and store it intotmp_6
- get "t" from
user_w_write_8_data
and store it intotmp_7
- get "h" from
user_w_write_8_data
and store it intotmp_8
- copy data from
tmp_1
touser_r_read_8_data
- copy data from
tmp_2
- copy data from
tmp_3
- copy data from
tmp_4
- copy data from
tmp_5
- copy data from
tmp_6
- copy data from
tmp_7
- copy data from
tmp_8
Then
- get "i" from
user_w_write_8_data
, swap "i" into "I" and store "I" intotmp_1
- get "s" from
user_w_write_8_data
- get " " from
user_w_write_8_data
- get "i" from
user_w_write_8_data
- get "s" from
user_w_write_8_data
- copy data from
tmp_1
- copy data from
tmp_2
- copy data from
tmp_3
- copy data from
tmp_4
- copy data from
tmp_5
Basically, the application should store 8 characters, swap the first char and then output these eight characters, store other eight characters, swap the first char and then output these eight characters etc. until it reads EOF
at the end of the input file.
PROBLEM: my application works if the input text contains a multiple of 8 characters (input text with 8 or 16 or 24 or 32 etc. characters). The problem is that when the input file does not have a multiple of 8 number of characters.
E.g: if input string is "hello this is" (12 characters), the application works until when it copies the first 8 characters ("hello th") but when it has to copy the next 5 remaining characters ("is is") the application does not write "is is" into read_device_file.
This problem occurs because when the input file reaches EOF
char, the application is not able to increment the counter
signal anymore (because user_w_write_8_wren = '0'
). In order to overcome this problem, I play with check
variable. More precisely, when the input file reaches EOF
the application:
-sets check
variable to 1
-when check
variable is 1, the application sets user_r_read_8_empty to '0'
(means that data is available in the next clock cycle) and sets the check
variable to 2
-when check
variable is 2, the application should output the remaining characters (in the previous example should output "is is")
The tmp_counter
signal is used to copy only the necessary remaining characters. E.g if the remaining characters are "is is" (five remaining characters), tmp_counter
will allow to copy only tmp_1
, tmp_2
, tmp_3
, tmp_4
and tmp_5
into user_r_read_8_data
and not tmp_6
, tmp_7
and tmp_8
By running the simulation on the test bench the application works fine but when I execute this application on the FPGA it does not copy the remaining characters. Where am I wrong?
EDIT 1: my_buffer.vhd
is the file in which I implemented the logic described above. I have improved the logic and instead of using EOF I check the full stop as suggested in the answer (I have removed case conversion because of limit characters):
library ieee;
use ieee.std_logic_1164.all;
entity my_buffer is
port (
bus_clk : in std_logic;
reset_8 : in std_logic;
-- Data from CPU via XillyBus
user_w_write_8_wren : in std_logic;
user_w_write_8_full : out std_logic;
user_w_write_8_data : in std_logic_vector(7 DOWNTO 0);
-- Data to CPU via XillyBus
user_r_read_8_rden : in std_logic;
user_r_read_8_empty : out std_logic;
user_r_read_8_data : out std_logic_vector(7 DOWNTO 0));
end my_buffer;
architecture rtl of my_buffer is
signal tmp_1 : std_logic_vector(7 downto 0); --tmp for the first char
signal tmp_2 : std_logic_vector(7 downto 0); --tmp for the second char
signal tmp_3 : std_logic_vector(7 downto 0); --tmp for the third char
signal tmp_4 : std_logic_vector(7 downto 0); --tmp for the fourth char
signal tmp_5 : std_logic_vector(7 downto 0); --tmp for the fifth char
signal tmp_6 : std_logic_vector(7 downto 0); --tmp for the sixth char
signal tmp_7 : std_logic_vector(7 downto 0); --tmp for the seventh char
signal tmp_8 : std_logic_vector(7 downto 0); --tmp for the eighth char
signal counter : integer := 0; --counter used to control the if else statements
shared variable check : integer := 0;
signal tmp_counter : integer := -1;
begin
process (bus_clk)
begin
if (bus_clk'event and bus_clk = '1') then
if user_w_write_8_wren = '1' then
if (user_w_write_8_data="00101110" and check=0 and counter<9) then --EOT:00000100, .:00101110
user_r_read_8_empty <= '0'; --data available in the next clock cycle
user_w_write_8_full <= '1'; -- now our data buffers are full
tmp_counter <= 1; --used to copy only the necessary remaing char. During every clock cycle it is decremented of 1 unit.
check := 1; --force the app to go into elsif statement down here
end if;
end if;
if (reset_8 = '1') then
-- reset has highest priority, initalize all state registers
user_r_read_8_empty <= '1'; -- no data available
user_w_write_8_full <= '1'; -- not ready yet
counter <= 0; -- counter starts at 0
elsif (counter = 0) then
-- just signal that we are ready for accepting data in the following cycle
user_w_write_8_full <= '0';
counter <= 1;
-- 1<=counter<=8 application copies data from user_w_write_8_data to tmp (swapping the first char)
elsif (counter = 1 and check=0) then
-- wait for first byte!
tmp_1 <= user_w_write_8_data; -- store the first char
--From upper case to lower case
--From lower case to upper case
-- user_w_write_8_full is kept low, thus, we are ready for accepting more data
counter <= 2;
end if;
elsif (counter = 2 and check=0) then
-- wait for second byte!
tmp_2 <= user_w_write_8_data; -- store the second char
counter <= 3;
end if;
elsif (counter = 3 and check=0) then
-- wait for third byte!
tmp_3 <= user_w_write_8_data; -- store the third char
counter <= 4;
end if;
elsif (counter = 4 and check=0) then
-- wait for fourth byte!
tmp_4 <= user_w_write_8_data; -- store the fourth char
counter <= 5;
end if;
elsif (counter = 5 and check=0) then
-- wait for fifth byte!
tmp_5 <= user_w_write_8_data; -- store the fifth char
counter <= 6;
end if;
elsif (counter = 6 and check=0) then
-- wait for sixth byte!
tmp_6 <= user_w_write_8_data; -- store the sixth char
counter <= 7;
end if;
elsif (counter = 7 and check=0) then
-- wait for seventh byte!
tmp_7 <= user_w_write_8_data; -- store the seventh char
counter <= 8;
end if;
elsif (counter = 8 and check=0) then
-- wait for eighth byte!
tmp_8 <= user_w_write_8_data; -- store the eighth char
user_r_read_8_empty <= '0'; -- we are ready for reading in the next cycle
counter <= 9;
end if;
-- 9<=counter<=16 application copies data from tmp to user_r_read_8_data
elsif (counter = 9 and check=0) then
--pull out tmp_1
if user_r_read_8_rden = '1' then
user_r_read_8_data <= tmp_1;
counter <= 10;
end if;
elsif (counter = 10 and check=0) then
--pull out tmp_2
user_r_read_8_data <= tmp_2;
counter <= 11;
end if;
elsif (counter = 11 and check=0) then
--pull out tmp_3
user_r_read_8_data <= tmp_3;
counter <= 12;
end if;
elsif (counter = 12 and check=0) then
--pull out tmp_4
user_r_read_8_data <= tmp_4;
counter <= 13;
end if;
elsif (counter = 13 and check=0) then
--pull out tmp_5
user_r_read_8_data <= tmp_5;
counter <= 14;
end if;
elsif (counter = 14 and check=0) then
--pull out tmp_6
user_r_read_8_data <= tmp_6;
counter <= 15;
end if;
elsif (counter = 15 and check=0) then
--pull out tmp_7
user_r_read_8_data <= tmp_7;
counter <= 16;
end if;
elsif (counter = 16 and check=0) then
--pull out tmp_8
user_r_read_8_data <= tmp_8;
counter <= 1;
end if;
end if;
--when application reached EOF and it did not copy the remaing characters
if (check = 1 and (tmp_counter<counter)) then --application is ready for coping the remaing char
if (tmp_counter=1 and (tmp_counter<(counter-1))) then --there data into tmp_1
tmp_counter <= 2;
end if;
elsif (tmp_counter=2 and (tmp_counter<counter)) then --there data into tmp_2
tmp_counter <= 3;
end if;
elsif (tmp_counter=3 and (tmp_counter<counter)) then --there data into tmp_3
tmp_counter <= 4;
end if;
elsif (tmp_counter=4 and (tmp_counter<counter)) then --there data into tmp_4
tmp_counter <= 5;
end if;
elsif (tmp_counter=5 and (tmp_counter<counter)) then --there data into tmp_5
tmp_counter <= 6;
end if;
elsif (tmp_counter=6 and (tmp_counter<counter)) then --there data into tmp_6
tmp_counter <= 7;
end if;
elsif (tmp_counter=7 and (tmp_counter<counter)) then --there data into tmp_7
tmp_counter <= 8;
end if;
elsif (tmp_counter=8 and (tmp_counter<counter)) then --there data into tmp_8
tmp_counter <= 9;
end if;
end if;
end if;
if (tmp_counter = counter) then
user_r_read_8_empty <= '1'; --no data available in the next clock cycle
tmp_counter <= -1;
end if;
end if;
end process;
end rtl;
Here is the xillydemo.vhd
. Because of body limited characters (30000) of stackexchange, I put only my_buffer component that I declared into xillydemo.vhd
--xillybus code here
component my_buffer
port (
bus_clk: IN std_logic;
reset_8: IN std_logic;
user_w_write_8_wren: IN std_logic;
user_w_write_8_full: OUT std_logic;
user_w_write_8_data: IN std_logic_VECTOR(7 downto 0);
user_r_read_8_rden: IN std_logic;
user_r_read_8_empty: OUT std_logic;
user_r_read_8_data: OUT std_logic_VECTOR(7 downto 0)
end component;
my_buffer_1: my_buffer
port map (
bus_clk => bus_clk,
reset_8 => reset_8,
user_w_write_8_wren => user_w_write_8_wren,
user_w_write_8_full => user_w_write_8_full,
user_w_write_8_data => user_w_write_8_data,
user_r_read_8_rden => user_r_read_8_rden,
user_r_read_8_empty => user_r_read_8_empty,
user_r_read_8_data => user_r_read_8_data);
-- these lines must be preserved in the XillyDemo
reset_8 <= not (user_w_write_8_open or user_r_read_8_open);
user_r_read_8_eof <= user_r_read_8_empty and not(user_w_write_8_open);
EDIT 2: This is the test bench that I use to run the simulation as suggested in the answer:
library ieee;
entity my_buffer_tb is
end my_buffer_tb;
architecture sim of my_buffer_tb is
signal bus_clk : std_logic := '1';
signal reset_8 : std_logic;
signal user_w_write_8_wren : std_logic;
signal user_w_write_8_full : std_logic;
signal user_w_write_8_data : std_logic_vector(7 DOWNTO 0);
signal user_r_read_8_rden : std_logic;
signal user_r_read_8_empty : std_logic;
signal user_r_read_8_data : std_logic_vector(7 DOWNTO 0);
begin
-- component instantiation
DUT: entity work.my_buffer
port map (
bus_clk => bus_clk,
reset_8 => reset_8,
-- clock generation
bus_clk <= not bus_clk after 5 ns;
-- waveform generation
WaveGen_Proc: process
begin
-- Input values sampled by the DUT with the first rising edge of bus_clk
reset_8 <= '1'; -- apply reset
-- other input values don't care during reset
wait until rising_edge(bus_clk);
-- Input values sampled by DUT with second rising edge of bus_clk
reset_8 <= '0';
user_w_write_8_wren <= '0';
user_w_write_8_data <= (others => '-');
user_r_read_8_rden <= '0';
--FIRST BUFFER
-- Add input assigmnents for next rising edge here
reset_8 <= '0';
user_w_write_8_wren <= '1';
user_w_write_8_data <= "01001000"; --H
reset_8 <= '0';
user_w_write_8_data <= "01000101"; --E
reset_8 <= '0';
user_w_write_8_data <= "01001100"; --L
reset_8 <= '0';
reset_8 <= '0';
user_w_write_8_data <= "01001111"; --0
reset_8 <= '0';
user_w_write_8_data <= "00100000"; --
reset_8 <= '0';
user_w_write_8_data <= "01010100"; --T
reset_8 <= '0';
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read H
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read E
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read L
reset_8 <= '0';
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read 0
reset_8 <= '0';
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read T
reset_8 <= '0';
--SECOND BUFFER
reset_8 <= '0';
user_w_write_8_data <= "01001001"; --I
reset_8 <= '0';
user_w_write_8_data <= "01010011"; --S
reset_8 <= '0';
reset_8 <= '0';
reset_8 <= '0';
reset_8 <= '0';
user_w_write_8_data <= "00101110"; --.
-- AFTER EOT
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read I
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read S
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read ' '
reset_8 <= '0';
reset_8 <= '0';
reset_8 <= '0';
user_r_read_8_rden <= '1'; --read .
-- no more data to read
-- finished
wait;
end process WaveGen_Proc;
end sim;
SIMULATION OUTPUT OK BUT PROBLEMS DURING THE EXECUTION ON FPGA: in the screenshot I have attached, it is possible to see that the simulation works. In particular, the program outputs the correct characters. The problem is that when I execute this program on the FPGA, it does not work. More precisely, I developed a Java application that copies the input string on write device file, the FPGA processes the input string and as soon as data is on read device file, the Java application prints out data on the terminal. I have tested the Java application and it works perfectly. The problems that occur when I execute this program on FPGA are:
- I can execute this program only 3 times. After the third time the program does not output data anymore. I order to overcome this problem I have to program the FPGA again but the program will work for the next 3 times.
- During the 3 times that the program works, the VHDL application outputs 2 times the last character (as in my previous screenshot)
The screenshot shows that the simulation works, but I don't know why, when I execute this program on FPGA the 2 problems described above occur. How is this possible?
