I'm new to VHDL and I'm trying to simulate an array multiplier.(I have used verilog before). However in the simulation results it shows 'X' for inputs which used to be '1'.Here is the result:enter image description here And this is the Testbench:
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
ENTITY array_multiplier_tester2 IS
END ENTITY;
ARCHITECTURE timed OF array_multiplier_tester2 IS
  SIGNAL A,B:std_logic_vector(3 DOWNTO 0):="0000";
  SIGNAL product:std_logic_vector(7 DOWNTO 0):="00000000";
BEGIN
 UUT:ENTITY WORK.array_multiplier(main)
    PORT MAP(A,B,product);
 A<="0000"; B<="0000";
PROCESS BEGIN
  WAIT FOR 23 NS;A(0)<='1';B(0)<=NOT B(0);
  WAIT FOR 23 NS;A(3)<='1';B(3)<='1';
  WAIT FOR 23 NS;A(2)<='1';B(2)<='1';A(0)<='0';B(0)<='0';
  WAIT FOR 23 NS;A(1)<='1';B(3)<='0';A(0)<='1';B(0)<='1';
  WAIT FOR 23 NS;A(3)<='0';B(2)<='0';
  WAIT;
END PROCESS;
END ARCHITECTURE timed;
I've also tried to use A<="0001" instead of A(0)<='1', but the result was the same. I'm using Modelsim for simulation.
I don't know why it shows 'X' for input!
You have multiple drivers for the signals A and B here:
and here:
PROCESS BEGIN
  WAIT;
END PROCESS;
The signal assignments at the first place continuously assign "0000" to A and B. These are not an assignment of an initial value.
Then your process assigns something to the same signals, thus, you have multiple drivers which are resolved. But, if you drive 0 at the first place and 1 in the process the resulting value is undefined shown as X in the simulation.
If you just want to initialize A and B, then move the first assignment into the process:
PROCESS BEGIN
  WAIT;
END PROCESS;
