12
this symbol is similar to solder bridge, but there is a connection on both end.
what does this symbol mean, and what is the equivalent pcb for this symbol
    \$\begingroup\$ The PCB footprint is pretty much what the circuit symbol is (except for the dots). \$\endgroup\$
    Commented Dec 30, 2015 at 19:42
It really is a solder bridge, with a separate trace connection as well. The trace can be cut if needed, and then the solder bridge can be used to rejoin the connection if circumstances change.
