The evaluation board
I am talking about the FTDI EVAL232R evaluation board which can be found at the bottom of this page. It employs a FT232RL IC.
What I want to do
I would like to connect a USB joystick to the board´s USB port, then connect the RS232 interface to my PC, move the joystick and check out the incoming stream of information.
What I tried
I know that those converters usually are used to program a microcontroller over USB and similar things. There the USB port connects to the PC and the RS232 interface to the chip. In the datasheet I can not find any clues as to which extent a reversed flow of information (from joystick to PC) is possible.
Is the above board the right one? If not, could you please point out a device that would better suit my needs?
Edit: I rephrased the title to make it more general.
closed as off-topic by Nick Alexeev Dec 31 '15 at 19:59
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ The discovery board with STM32F407VG for example should work with for your project. You need a device that can act as a host. \$\endgroup\$ – JavaForStarters Dec 31 '15 at 20:25
  • \$\begingroup\$ Have you thought about just using an Arduino with a joystick and breakout board? Here is a 2-axis one: adafruit.com/products/… \$\endgroup\$ – jonnyd42 Dec 31 '15 at 20:30
  • \$\begingroup\$ @canbus Thank you for the hint, until now I only checked AVR microcontrollers and I did not find one with host capability. \$\endgroup\$ – pat3d3r Dec 31 '15 at 21:04
  • \$\begingroup\$ @jonnyd42 Thank you also, but I really want to use my Saitek X52 joystick for this project. \$\endgroup\$ – pat3d3r Dec 31 '15 at 21:05
6
The FT232 chips are USB-UART bridges that act as USB devices. From your description, you want it to act as a USB host. That won't work.
