6
Could anyone explain how does Pseudo Direct Addressing work in MIPS?
I don't really get how does using the last 4 bits from the PC (Program Counter) fit into the picture?
Suppose I want to goto Address
0000 0000 0000 0000 0000 0000 0000 0100
And my PC looks like 0101 ...
Then I can't? Because I will need the last 4 bits to look like 0101 instead? So it will somewhat be relative to PC too?
    \$\begingroup\$ Why the vote to close? In general, microcontroller programming questions have been allowed in this forum. Note under RELATED in the right sidebar the number of MIPS questions. \$\endgroup\$
    – tcrosley
    Oct 14 '11 at 16:44
    \$\begingroup\$ @tcrosley and the close voter - Please submit your opinion at this Meta discussion \$\endgroup\$ Oct 14 '11 at 18:41
MIPS pseudo-direct addressing takes the upper four bits of the program counter, concatenated with the 26 bits of the direct address from the instruction, concatenated with two bits of 0 0:
PC31...PC28    IM25...IM00    0    0
which creates a complete 32-bit address. This format is used by the J-type instructions, j and jal. Since the upper 4 bits of the PC are used, this constrains the jump target to anywhere within the current 256 MB block of code (1/16 of the total 4 GB address space). To jump anywhere within the 4 GB space, the R-type instructions jr and jalr are used, where the complete 32-bit target address is specified in a register.
The reason for forcing the bottom two bits to 0 is that all instruction addresses in MIPS are 32-bit word aligned, so you can never have a target address of a jump instruction with the two bits anything other than 0 0.
  • \$\begingroup\$ So i suppose the 256MB comes from 2^28? \$\endgroup\$
    – Jiew Meng
    Oct 15 '11 at 0:55
  • \$\begingroup\$ @jiewmeng, correct. The top 4 bits, coming from the program counter, select 1 of 16 "banks" of 256 MB, and the low 28 bits select a byte within that bank. But as previously mentioned, only bytes with an address modulo 4 == 0 are allowed since the bottom two bits are always 0 0. \$\endgroup\$
    – tcrosley
    Oct 15 '11 at 5:25
