Above is a part of a BJT common emitter amplifier with 15V Vcc(all caps ignored for DC). I was following a tutorial which explains how to setup parameters step by step. When explaining the DC biasing section, the tutorial first sets up values for Q point Vce i.e VceQ, Rc and Re.
For a maximum Vout swing, we should choose VceQ as Vcc/2. This can be seen by a DC load-line. I think it is because the maximum change in Vce will logically yield a maximum swing in Vout. At Q point we can then take VceQ = 7.5V. So far so good..
Then the tutorial chooses the ratio of Rc/Re as 3 i.e Rc = 3*Re. And then it goes to investigate other parameters without explaining why the ratio is 3.
I tried to setup this ratio first 3 and then 4 and then 14. What I found out is the more the ratio the more swings the Vout.
Since we know Vcc = 15V and at Q point VceQ = 7.5V, we can check Vout for different Rc/Re ratios.
Case_1:
Lets first take Rc/Re as 3 as the tutorial suggests:
Vout_max (when Q1 is in cut-off) becomes: 15V
Vout_middle (when bias current is zero) becomes: VceQ + (15-VceQ)/4 = 9.5V
Vout_min (when Q1 is in saturation and Vcesat = 0.2) becomes as follows:
Vcesat+(15-Vcesat)/4 = 3.9V
So what we see above is a Vout which has a middle point at 9.5V when no bias current exists and which swings up to 15V and down to 3.9V. This corresponds a total swing of 11V.
Case_2:
Now lets take Rc/Re ratio as 14 and redo the same calculation:
Vout_middle (when bias current is zero) becomes: VceQ + (15-VceQ)/15 = 8V
Vcesat+(15-Vcesat)/15 = 1.2V
Here what we see above is a Vout which has a middle point at 8V when no bias current exists and which swings up to 15V and down to 1.2V. This corresponds a total swing of around 14V.
Here is my question:
1-) If my logic is right it seems to me Rc/Re ratio determines the Vout swing (after setting VceQ as Vcc/2). And the Vout swing increases with Rc/Re ratio. Is that right?
2-) Of course Re shouldn't be too small but what is the rule of thumb here for Rc/Re ratio? And why?
  • \$\begingroup\$ your schematic doesn't show this, so it might not be applicable, but if you put on an AC coupled load (big capacitor in series to the output), the AC load line and the DC load line are different. and the Vout swings will be along the AC load line and you want that swing to be maximum without clipping on either top or bottom. \$\endgroup\$ – robert bristow-johnson Jan 1 '16 at 22:44
  • \$\begingroup\$ i know Im not asking that. Thats why I didnt draw caps. Forget about AC for now. This is about setting DC bias point and resistors. Im asking at the beginning when we set up DC bias point why we choose Rc/Re ratio as 3- \$\endgroup\$ – user16307 Jan 1 '16 at 22:47
  • \$\begingroup\$ check this nice tutorial. question is related to this video tutorial: youtube.com/watch?v=1IYOGhS2OZc the resistors are in ratio as Rc/Re is 3. Why not 4 why not 14 that's my question. check video after 2:45 \$\endgroup\$ – user16307 Jan 1 '16 at 22:49
They apparently set the Rc/Re ratio to 3 because they wanted a voltage gain of about 3. Presumably that was desirable for the role of this circuit. Basically the Rc/Re ratio is the voltage gain assuming the transistor's gain is "large". Large means that you can approximate the collector and emitter currents as being equal, which also means the base current is 0.
You are right in that the Rc/Re ratio also sets the fraction of the supply voltage that the output can swing. As a simplification, consider that the transistor can vary from open to short C to E. When open, the collector (output) voltage is Vcc. When short, it is Vcc out of the voltage divider formed by Rc and Re. When Rc/Re is large, the output when the transistor is fully on approaches 0, and the output can swing the whole 0 to Vcc range. When Re is a significant fraction of Re+Rc, then it eats up some of the output voltage when the transistor is on, and the output can't swing as low to ground.
For good linear operation, you want to leave about a volt or so across C-E. The lowest output voltage swing is therefore Vcc-1V divided by the resistor divider, plus the 1 V across the transistor:
  Vomin = [(Vcc - 1V) Re / (Re + Rc)] + 1V
At high Rc/Re ratios, this approaches the 1 V you leave across the transistor. For lower ratios, the output voltage swing "lost" to Re is significant. All this is to say, yes, you're right, the output voltage swing depends on Rc/Re.
There is no rule of thumb for setting Rc/Re. This is basically the voltage gain of the amplifier. You set this to what it needs to be for other reasons.
However, you can't just make the gain infinite since then other factors that we can reasonably ignore at modest gains get in the way. These other factors are often hard to know. I'd say, try not to exceed a voltage gain of about 1/5 the transistor current gain. That's of course a tradeoff I picked out of the air, but with a reasonably good transistor gain, like 50 or more, a voltage gain of 10 is doable. Beyond that, the approximation that the transistor gain is "large" and you can mostly ignore the base current becomes less valid. So does the approximation that the B-E voltage is fixed.
As you can see at high gains the exact parameters of the transistor matter more and more. Since transistor gain varies widely, we generally want circuits to work with some minimum gain, but not rely on any maximum gain. Put another way, we want circuits to work with transistor gain from some minimum to infinity. The higher the gain, the more sensitive the circuit is to the transistor's gain and other parameters.
As a exercise, see what happens in your circuit when Rc/Re = 3 and the transistor gain is 50 (a quite reasonable minimum guaranteed value for a small signal transistor). Then analyze it again with infinite gain. You'll see only a rather small difference. Now do the same with a gain of 30, and you'll see much more sensitivity to the transistor gain.
As you reduce Re, you reduce the voltage across it. Now you want to fix Vb at Vbe + V(Re) by selecting R1,R2.
So far, so good ... but remember that Vbe is not precisely 0.6 or 0.7V, but a function of Ib (as is the voltage across a forward biassed diode) and of temperature : it decreases by 2mV/K. So over a 50K temperature range, Vbe can vary by 0.1V. Because you fixed Vb, this causes variations in V(Re), hence Ie, hence Ic, hence V(Rc).
So V(Re) should be large compared with these variations, and usually > Vbe unless you're seriously pressed for headroom (e.g. 3V supply). Here, I ask, how important is that last 10% (1dB) of voltage swing? I would suggest Rc/Re < 10 as a good rule, and I'd look for 2*Vbe across Re if possible.
  • \$\begingroup\$ im not designing this. but i was learning and was very curious why it is chosen such way as 3. here is the part of tutorial video: youtu.be/1IYOGhS2OZc?t=145 \$\endgroup\$ – user16307 Jan 1 '16 at 23:21
  • \$\begingroup\$ do you mean if we setup the swing too large then we are in danger of clipping since Vbe is not stable enough? \$\endgroup\$ – user16307 Jan 1 '16 at 23:28
  • \$\begingroup\$ Yes - clipping, or variations in DC output level, or in power consumption etc, none of which are very desirable. I don't know why your tutorial chose Rc/Re=3 - perhaps excess caution, perhaps he felt anything higher delivered minimal improvement. But it wasn't one of the specific questions you asked. In short I think it's OK to push Rc/Re beyond 3, but not too far. You might find it interesting to play with an extreme case in simulation, and vary the temperature of the transistor. \$\endgroup\$ – Brian Drummond Jan 1 '16 at 23:35
  • \$\begingroup\$ Olin's answer re: gain variability is also important, but even more important when considering AC gain (with a capacitor or R-C network across Re) \$\endgroup\$ – Brian Drummond Jan 2 '16 at 0:24
