The formula for the output current of a LM317 is:
LM317 CC regulator
In this schematic, what will the output current be?
MY approach:
I thought R in this formula is the resistance LM317 sees. so I should calculate the whole resistance. it will be:
$$\left( \frac1{R_1}+\frac1{R_2+R_3}\right)^{-1}$$
but how can I neglect the node R2-R3 which current is being sunken through?
So I tried Delta-wye conversion :
$$R_{13}=\frac{R_1R_3}{\sum R_{\Delta}}$$ $$R_{12}=\frac{R_1R_2}{\sum R_{\Delta}}$$
So the resistance LM317 sees will be R13 + R12.
Which approach is correct? Am I right at all?
  • 4
    \$\begingroup\$ The circuit you made doesn't make sense. There is no load and the maximum input current into the adjust terminal is 100uA. This exercise is not realistic or useful. What is it you are trying to demonstrate or learn ? \$\endgroup\$
    – efox29
    Jan 2, 2016 at 20:06
The key to the circuit is the current going through R1 that gives you the Vref.
Trying to solve this circuit by going the route of using the resistance the LM317 sees will not work, because that would build in a wrong assumption of how the current would flow.
Assuming the current through the ADJ pin is negligible (and the voltages and load are in the regulating range of the LM317), a step by step approach works:
As defined by the operating point of the LM317, \$ V_{R1} = V_{REF} \$: $$ I_{R1} = \frac{V_{REF}}{R_1} $$
Given \$ I_{R1} = I_{R2} \$: $$ V_{R2} = I_{R1} R_2 $$
Given \$ V_{R3} = V_{R1} + V_{R2} \$: $$ I_{R3} = \frac{V_{REF}+V_{R2}}{R_3} $$
$$ I_{OUT} = I_{R1} + I_{R3} $$
It turns out quite straight forward and you can substitute from top to bottom to get a simple formula.
  • \$\begingroup\$ I understood non of your step by step approach. can you tell the reason why those four MathJax lines are true? \$\endgroup\$
    – AHB
    Jan 3, 2016 at 6:29
  • \$\begingroup\$ 1: that's the operating point of the regulator 2: by kirchoffs node law. 3: by kirchoffs ring law 4: by kirchoffs node law. \$\endgroup\$ Jan 3, 2016 at 7:29
  • \$\begingroup\$ Jasen has given the explanations. I have also edited the post to give additional info. \$\endgroup\$
    – rioraxe
    Jan 3, 2016 at 7:55
  • \$\begingroup\$ @rioraxe I got them now. thx. \$\endgroup\$
    – AHB
    Jan 6, 2016 at 9:18
