This is the output of ISim simulation:
ISim
I want to decrease tx_data_ctr by 1 when flags_from_clk_div turns to 4'b0000 so sda_flag_from_transmit_byte take initial bit from tx_data[7:0]. However, I could not find a way to do it. What I actually ask is if there is a way to set flag or do something else synchronously with the certain change of a register?
It is like @(reg_x == 4'b0001) - do_stuff but of course I know there is no such command.
Also, is one able to do stuff with posedge like when register change immediately execute something?
I use configurations like:
always @(posedge start) begin
  // stuff stuff
end
but can we apply something like this to a register has more than one byte? I hope I could explain.
edit: I added codes below:
scl_counter.v:
module scl_counter(
    input rst,
    input start,
    output reg [3:0] flags,
    input clk
parameter clk_divider = 0;
reg [15:0] scl_counter;
    flags = 4'b0;
    scl_counter = 16'b0;
end
always @(posedge clk) begin
    if (rst) begin
        flags = 4'b0;
    end
    else if (!rst) begin
        if (clk_divider != 1) begin
            if (scl_counter != (clk_divider*2)) begin
                scl_counter = scl_counter + 1;
                if (scl_counter == (clk_divider/2)) begin
                    flags[0] = 1'b1;
                end
                else if (scl_counter == (clk_divider*3/2)) begin
                    flags[1] = 1'b1;
                end
            end
            else if (scl_counter == (clk_divider*2)) begin
                flags = 4'b0;
            end
        end
        else if (clk_divider == 1) begin
        end
    end
end
endmodule
transmit_byte.v:
`include "scl_counter.v"
module transmit_byte(
        output reg [0:0] sda_flag_from_transmit_byte,
        input [7:0] tx_data,
        output reg [7:0] rx_data,
        input clk,
        output reg [0:0] scl_flag_from_transmit_byte,
        input start_scl_div,
        output reg [0:0] reset_to_clk_div,
        input [3:0] flags_from_clk_div,
        output reg [2:0] tx_data_ctr
reg [2:0] rx_data_ctr;
reg [0:0] ready_to_start_flag;
reg [0:0] resetter_flag_clk_div;
always @(posedge start_scl_div) begin
    scl_flag_from_transmit_byte = 1'b0;
    ready_to_start_flag = 1'b0;
    resetter_flag_clk_div = 1'b0;
    tx_data_ctr = 3'b111;
    rx_data_ctr = 3'b0;
    ready_to_start_flag = #1 1'b1;
end
always @(negedge clk)
begin: RESETTER_TO_CLK_DIV
    if (ready_to_start_flag) begin
        if (start_scl_div) begin
            if (resetter_flag_clk_div == 1'b1) begin
                reset_to_clk_div = 1'b0;
            end
            else if (resetter_flag_clk_div == 1'b0) begin
                reset_to_clk_div = 1'b1;
                resetter_flag_clk_div = 1'b1;
            end
        end
    end
end
            if (flags_from_clk_div == 4'b0) begin
                sda_flag_from_transmit_byte = tx_data[tx_data_ctr];
            end
            else if (flags_from_clk_div == 4'b0001) begin
                scl_flag_from_transmit_byte = 1'b1;
            end
            else if (flags_from_clk_div != 4'b0001) begin
            end
        end
    end
end
always @(negedge start_scl_div) begin
end
//b01100100
scl_counter #(16'b00001000) c_1(
    .rst    (reset_to_clk_div),
    .start  (start_scl_div),
    .flags  (flags_from_clk_div),
    .clk    (clk)
endmodule
timer_A.v:
module timer_A(
    input clk,   // which clock?
    input rst,   // sets to 0 or up counter
    //output [7:0] flags_timer_A,   // sets flag when counts to the value
    input mode,   // if mode 0, counts up to A only flags A, if 1 counts to
                        // A and B, C, D ... flags if they are not 0.
    input [15:0] count_to_A,  // counts to first value
    input [15:0] count_to_B,  // counts to second value
    input count_to_C,
    input count_to_D,
    input count_to_E,
    input count_to_F,
    input count_to_G,
    input count_to_H,
    output reg [7:0] flags_timer_A
reg [15:0] timer_A_Reg;
//reg [7:0] flags_timer_A;
timer_A_flag_A  = flags_timer_A[0]
timer_A_flag_B  = flags_timer_A[1]
timer_A_flag_C  = flags_timer_A[2]
timer_A_flag_D  = flags_timer_A[3] ...
always @(posedge rst) begin
    flags_timer_A = 8'b0;
    timer_A_Reg = 16'b0;
end
    if (rst) begin
    end
        if (mode == 1'b0) begin
            if (timer_A_Reg != count_to_A) begin
                timer_A_Reg <= timer_A_Reg + 1;
            end
            else begin
                flags_timer_A[0] <= 1'b1;
            end
        end
        else begin
                timer_A_Reg = timer_A_Reg + 1;
                if (timer_A_Reg == count_to_B) begin
                    flags_timer_A[1] = 1'b1;
                end
                else if (timer_A_Reg == count_to_C) begin
                    flags_timer_A[2] = 1'b1;
                end
                else if (timer_A_Reg == count_to_D) begin
                    flags_timer_A[3] = 1'b1;
                end
                else if (timer_A_Reg == count_to_E) begin
                    flags_timer_A[4] = 1'b1;
                end
                else if (timer_A_Reg == count_to_F) begin
                    flags_timer_A[5] = 1'b1;
                end
                else if (timer_A_Reg == count_to_G) begin
                    flags_timer_A[6] = 1'b1;
                end
                else if (timer_A_Reg == count_to_H) begin
                    flags_timer_A[7] = 1'b1;
                end
            end
            else begin
            end
        end
    end
end
endmodule
start_i2c.v:
    `include "timer_A.v"
    module start_i2c(
            input start,
            input [7:0] flags_timer_A,
            input clk,
            output reg [0:0] rst_to_tmr,
            output reg [0:0] start_done,
            output reg [0:0] scl_flag_from_start_i2c,
            output reg [0:0] sda_flag_from_start_i2c
    reg [0:0] resetter_flag;
    reg [0:0] mode_to_tmr;
    timer_A_flag_A  = flags[0]
    timer_A_flag_B  = flags[1]
    timer_A_flag_C  = flags[2]
    timer_A_flag_D  = flags[3] ...
        resetter_flag <= 1'b0;
        mode_to_tmr <= 1'b1;
        start_done <= 1'b0;
        scl_flag_from_start_i2c <= 1'b1;
        sda_flag_from_start_i2c <= 1'b1;
    end
    parameter min_SDA_on_time = 0;
    parameter min_SDA_SCL_fall_delay = 0;
    begin: RESETTER    // this resets up when start is on immediately
        if (start && !resetter_flag) begin
            rst_to_tmr = 1'b1;
            resetter_flag = 1'b1;
        end
        else if (start && resetter_flag) begin
            rst_to_tmr <= 1'b0;
        end
    end
        if (start) begin
            if (flags_timer_A[1]) begin
                sda_flag_from_start_i2c <= 1'b0;
            end
            if (flags_timer_A[0]) begin
                scl_flag_from_start_i2c <= 1'b0;
                start_done <= 1'b1;
            end
        end
        else begin
        end
    end
    always @(negedge start) begin
        resetter_flag = 1'b0;
        //start_done <= 1'b0;
    end
    timer_A  start_timer(
        .clk             (clk),   // which clock?
        .rst             (rst_to_tmr),   // sets to 0 or up counter
        .mode     (mode_to_tmr),   // if mode 0, counts up to A only flags A, if 1 counts to
        .count_to_A      (min_SDA_on_time + min_SDA_SCL_fall_delay),  // counts to first value
        .count_to_B      (min_SDA_on_time),  // counts to second value
        .count_to_C      (16'b0),
        .count_to_D      (16'b0),
        .count_to_E      (16'b0),
        .count_to_F      (16'b0),
        .count_to_G      (16'b0),
        .count_to_H      (16'b0),
        .flags_timer_A   (flags_timer_A)  // sets flag when counts to the value
    endmodule
**start_i2c_tb.v:**
`include "start_i2c.v"
`include "transmit_byte.v"
module start_i2c_tb(
//defparam start_test.min_SDA_on_time = 16'b11001000;
//defparam start_test.min_SDA_SCL_fall_delay = 16'b01100100;
reg [0:0] start_start_i2c;
reg [0:0] start_scl_div;
reg [7:0] tx_data;
wire [7:0] flags_timer_A;
reg [0:0] clk;
wire sda_flag_from_transmit_byte;
wire scl_flag_from_transmit_byte;
wire scl_flag_from_start_i2c;
wire sda_flag_from_start_i2c;
wire [3:0] flags_from_clk_div;
wire [2:0] tx_data_ctr;
initial begin
    clk = 1'b0;
    start_scl_div = 1'b0;
    start_start_i2c = 1'b0;
    #5 start_start_i2c = 1'b1;
    tx_data = 8'b10101010;
    #40000 $finish;
end
always begin
    #1 clk = ~ clk;
end
always @(clk) begin
    if (start_done && start_start_i2c) begin
    end
    else if (start_done && !start_start_i2c) begin
        start_scl_div = 1'b1;
    end
end
start_i2c #(16'b11001000, 16'b01100100) start_test(
        .start          (start_start_i2c),
        .flags_timer_A  (flags_timer_A),
        .clk            (clk),
        .rst_to_tmr     (rst_to_tmr),
        .start_done     (start_done),
        .scl_flag_from_start_i2c            (scl_flag_from_start_i2c),
        .sda_flag_from_start_i2c            (sda_flag_from_start_i2c)
transmit_byte start_transmit(
        .sda_flag_from_transmit_byte       (sda_flag_from_transmit_byte),
        .tx_data   (tx_data),
        .rx_data   (rx_data),
        .clk       (clk),
        .scl_flag_from_transmit_byte       (scl_flag_from_transmit_byte),
        .start_scl_div   (start_scl_div),
        .reset_to_clk_div  (reset_to_clk_div),
        .flags_from_clk_div  (flags_from_clk_div),
        .tx_data_ctr   (tx_data_ctr)
endmodule
EDIT: Based on Dave Tweed's answer, I added the following code block and it works now. Is it right way to do it?
        if (tx_check) begin
            tx_data_ctr = tx_data_ctr + 1;
            tx_check = 1'b0;
        end
    end
    if (flags_from_clk_div == 4'b0011) begin
        tx_check = 1'b1;
    end
end
You can always create a new signal that represents the condition you want to test, such as:
wire x_is_one = (x == 1);
Then you can look for events on that signal.
However, basing a design on a lot of asynchronous events is a risky approach, very prone to error. Try to find a synchronous solution — one in which all of the logic is clocked by a common clock. This is especially true when working with FPGAs, for which both the hardware architecture and the software tools are strongly oriented toward synchronous designs.
  • \$\begingroup\$ Thanks for the answer. always @(posedge clk) begin if (flags_from_clk_div == 4'b0) begin if (tx_check) begin tx_data_ctr = tx_data_ctr + 1; tx_check = 1'b0; end end if (flags_from_clk_div == 4'b0011) begin tx_check = 1'b1; end end I added this code block and it works now. Is it right way to do it? \$\endgroup\$
    – Alper91
    Jan 3, 2016 at 11:05
    \$\begingroup\$ I took the liberty of adding the new code to your question as an edit so that I can read it. Yes, it's the right idea, but you have many other problems in your code. Specifically, you can't have assignments to the same signal in multiple always blocks -- it may work in simulation, but you will not be able to synthesize real logic based on it. \$\endgroup\$
    – Dave Tweed
    Jan 3, 2016 at 12:37
  • \$\begingroup\$ You mean like in different always blocks like: @(posedge clk) and @(negedge clk) or same always blocks (two @(posedge clk) )but coded seperately in the debugger? \$\endgroup\$
    – Alper91
    Jan 3, 2016 at 13:20
    \$\begingroup\$ @Alperözel a register can only be driven by exactly one always block, using exactly one clock edge. \$\endgroup\$ Jan 3, 2016 at 14:19
    \$\begingroup\$ @Alperözel, IDE's don't want about about registers driven from two always blocks because it is legal non-synthesizable behavioral modeling; for example a model of a analog block. If you enable SystemVerilog and change always to always_ff for synchronous blocks (and always @* to always_comb` for combinational blocks) then the compiler will throw errors when two always blocks drive the same register. \$\endgroup\$
    – Greg
    Jan 3, 2016 at 15:58
Based on the updated code that you have posted I wanted to add some changes.
  if (flags_from_clk_div == 4'b0000) begin
      if (tx_check) begin
          tx_data_ctr <= tx_data_ctr + 1;
          tx_check <= 1'b0;
      end else begin
          // do something here
      end
  end else if (flags_from_clk_div == 4'b0011) begin
      tx_check <= 1'b1;
  end else begin
  end
end
When you are @posedge of clock it is a good practice to use the non blocking operator(<=)
The else I have added after each if is to avoid creating a latch
Also try to replace the outer if else if logic I have used above with a case statement as it may end up producing better logic during synthesis
Finally try using a asynchronous reset in the clocking block to initialize all the variables.
