I'm studying differents GSM/GPRS modules and all of them have two operation modes depending the frecuency (900MHz and 1800Mhz). If I'm not wrong, for the same power higher frecuencies have a lower reach and higher trassmision rate than lower frecuencies.
My question is, how can I know the reach in meters of each range for a power of 2W or 33dBm in 900MHz and 1W or 30dBm in 1800MHz.
Thanks for your time!
  • \$\begingroup\$ Sorry, I forgot write it... The question is for ideal conditions. Thanks! \$\endgroup\$ – ferdepe Jan 4 '16 at 13:21
Irrespective of frequency, the power radiated from an antenna is the same (if the power input to that antenna is constant). This means that at some arbitrary distance from a transmitting antenna, the same power density is present (watts per square metre) irrespective of frequency.
However, because a receiving antenna has a size that is dependent on wavelength, the effective area is becomes smaller with an increase in frequency. The bottom line is that the antenna receives less power and produces a smaller signal as frequency rises.
The formula that I use for the free-field assessment of link loss (power loss between transmit and receive antennas) is based on the Friis formula: -
Link Loss (dB) = 32.4 + 20\$log_{10}\$(F) + 20\$log_{10}\$(d)
where F is MHz and d is distance between the two antennas (kilometres).
If "F" were 2 (implying a doubling of operating frequency) the loss part of the equation would increase by 6.02 dB.
To know how far you can get ideally in free-space you need to have a figure for the data rate you transmit at. If the data rate is really low you can design a receiver that has a very tight band-pass filter that excludes a lot of noise - this allows you to receive a signal that is much smaller and therefore distance can increase. Anyway the rule of thumb equation is this: -
Power required by receive antenna in dBm is -154dBm + 10\$log_{10}\$(data rate) dBm
So now you have an estimate of the power you need at the receiver based on data rate, a formula that describes how power is attenuated in free-space (link-loss) and you have your output power (1 or 2 watts). All you need to do is combine this lot together to get an estimate. On the good side, the gain (dBi) of the sending and receiving antennas makes the link-loss smaller. On the down side, operating conditions can vastly increase the link-loss both statically and dynamically. In fact this is a big subject and has spawned several different mathematical models by cellular handset companies and other interested parties.
The most basic form this takes is to say that link-loss will be at least 20 dB worse than the free-space model - the 20 dB factor is called Fade margin. There is also another commonly used models for link loss here. This is the Hata model for open areas: -
where
  • LO = Path loss in open area. Unit: decibel (dB)
  • LU = Path loss in urban areas for small sized city. Unit: decibel (dB)
  • f = Frequency of transmission. Unit: Megahertz (MHz).
There is also the Okumura model for urban areas: -
where,
L = The median path loss. Unit: Decibel (dB)
LFSL = The free space loss. Unit: decibel (dB)
AMU = Median attenuation. Unit: decibel (dB)
HMG = Mobile station antenna height gain factor.
HBG = Base station antenna height gain factor.
Kcorrection = Correction factor gain (such as type of environment, water surfaces, isolated obstacle etc.)
You also might be interested in this website for estimating range. There is also this calculator.
| improve this answer | |
