I'm using CC2640, and N25Q128A (Micron Serial NOR Flash Memory). SPI is working well, erase and write commands are changing the status register so busy flag rises and i'm waiting until it's clear.
The only problem i'm facing is read command, when i'm sending the read command with 3 byte of address the memory is rising miso pin and does not release until c# pin is rise again.
I cleared the ReadLock register and set the WriteEnable register, and now here i am... asking why it's happen and how to fix the issue?
