A USB 2.0 Cable should have 4 cables. They are the Vcc, Data+, Data- and Ground.
Will only disconnecting the Vcc OR Ground Wires damage the Connected Device or the Data Wires?
I currently have a USB SD Card reader that I like to Disconnect and Connect. The reader is mounted on the table, so to disconnect the reader, I would plug off the USB Cable connecting the reader and the computer.
To solve this problem, I would like to place a switch in the power lines, but I wonder if this will break the device since the Data cables are still connected but the power lines are disconnected.
Any answer will be Appreciated. Thanks in Advanced
  • \$\begingroup\$ Depends on the device connected to it \$\endgroup\$ – d3L Jan 6 '16 at 16:22
  • \$\begingroup\$ @d3l The device is an SD Card reader that is connected to a computer \$\endgroup\$ – Bryan Jan 6 '16 at 16:24
Put a disconnect switch in the power line, but leave the ground connected all the time. This works fine and does what you expect.
(Obviously if you try this with a self-powered USB hub or device it may ignore you turning the power off, but most are bus-powered devices.)
put the switch on the data lines. USB is designed so that the data lines connect after the power connects. reversing that timing may have unexpected consequences,
  • \$\begingroup\$ @Bryan, to (over-) clarify Jasen's point, if you look into a USB connector you should see the outer gold contacts are longer to ensure that power connects first. \$\endgroup\$ – Transistor Jan 7 '16 at 0:09
