I am making a system that requires the white wires and the green wires (in usb cables) need to kind of be on a diode. Which one goes to the computer and which goes to the USB device?
USB uses bidirectional differential signaling on the data lines - data is tranmitted both ways (one way at a time) over the pair of data wires.
USB is a very complex communication system, and shouldn't be messed with, unless you really understand the system.
| improve this answer | |
The White wire in a USB is the Data- wire
The Green Wire in a USB is the Data+ wire
Edit : Apparently, I was wrong.
  • \$\begingroup\$ This is incorrect, USB (up to 2.0) is half-duplex bidirectional signalling over a single differential pair. \$\endgroup\$ – uint128_t Jan 7 '16 at 3:37
  • \$\begingroup\$ USB uses differential signalling - data is sent on both wires simultaneously, one way at a time. You can't call one wire TX and the other RX. \$\endgroup\$ – Peter Bennett Jan 7 '16 at 3:39
  • \$\begingroup\$ @uint128_t Thanks for telling me that Im wrong. I am still too learning about electonics \$\endgroup\$ – Bryan Jan 7 '16 at 3:43
  • \$\begingroup\$ @PeterBennett Thanks for telling me that Im wrong. I am still too learning about electronics \$\endgroup\$ – Bryan Jan 7 '16 at 3:44
