So I was trying to write a code to connect an SD card to my atxmega128 . Code is nearly ready but when I want to compile it in Atmel Studio, I get errors about not declaring some codes. Some of the undeclared codes are "PORTD , PORTD_DIR, ... " . Question : Aren't these port codes part of the atmel studio software? Do I need to define some source codes for them ? What should I do to make it work ?
  • \$\begingroup\$ Did you forget to include <avr/io.h>? Are you writing IAR code for the GCC compiler? \$\endgroup\$ Jan 7, 2016 at 8:21
  • \$\begingroup\$ Nope! I didn't forget that. \$\endgroup\$
    – Mike Gh
    Jan 7, 2016 at 8:29
These sort of things should be included in avr/io.h, which you should be including at some point. Check to make sure you have
#include <avr/io.h>
in the appropriate locations (top of C files and/or included header files).
  • \$\begingroup\$ I've included io.h and iox128a.h . problem still remains. actually there's nothing about ports and port_dir in these h files. \$\endgroup\$
    – Mike Gh
    Jan 7, 2016 at 8:28
  • \$\begingroup\$ try #include "avr/io.h" \$\endgroup\$
    – kabZX
    Jan 7, 2016 at 8:33
    \$\begingroup\$ There is no iox128a.h. Only iox128a1.h, iox128a1u.h, iox128a3.h, iox128a3u.h, and iox128a4u.h. All of these files define PORTD and PORTD_DIR, among many other things. However, you should not have to include anything beyond avr/io.h as this file will automatically include the device-specific file. Are you correctly specifying what the target device is to the compiler? \$\endgroup\$ Jan 7, 2016 at 8:50
If you're using ASF then put an include to asf.h in the header file of the part you're working on. It's the easiest way to fix any of these problems.
#include <asf.h>
