Which Switching Device can Switch from Off to On and Off the fastest?
- Transistor
- Solid State Relay
- or Mechanical Relay
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhich Switching Device can Switch from Off to On and Off the fastest?
Transistors are used in extremely high frequency radio amplifiers and transmitters (we're talking frequencies that are many GHz). They are also used in very high speed devices such as CPUs, FPGAs, logic devices and the list of high speed devices goes on and on.
Solid state relays are quite often used to turn on and off an appliance connected to a 50 or 60 Hz power AC supply as are mechanical relays. However mechanical relays need to physically move an armature to perform a switching action.
Based on what I've said, what do you think is the fastest device.
Speed of switching vs Component.
Time 0-------------------------------------------------Eternity (~25mS)
Transistor |***** SSR |******* Relay |***************************************************************>> Capiche?
