What is the recommended way to make solid connections to the pins below? Can the soldering be avoided, and if not, what component should be used to provide the plug/unplug connection?
  • \$\begingroup\$ You need a socket. FPC/FRC Sockets are a way to go. Google might help. \$\endgroup\$ – ammar.cma Jan 7 '16 at 13:45
    \$\begingroup\$ "PCB edge connector" is a common name for what you're looking for. \$\endgroup\$ – user_1818839 Jan 7 '16 at 13:50
  • \$\begingroup\$ @BrianDrummond The picture might be a bit misleading, but I don't believe it's an edge connector. The whole board isn't supposed to be plugged into a slot \$\endgroup\$ – TheMeaningfulEngineer Jan 7 '16 at 14:01
  • \$\begingroup\$ @Alan can you post a picture of the whole PCB? \$\endgroup\$ – marco-a Jan 7 '16 at 14:03
  • \$\begingroup\$ @d3l Updated with a larger picture. It show the pins I'm referring to \$\endgroup\$ – TheMeaningfulEngineer Jan 7 '16 at 14:06
Thanks all the guys that commented. There seems not to be a solution that doesn't include soldering. There are some suggestions to use PCB edge connectors but those would not be a solution if the pins are located in the middle of the PCB.
The component name to use is an "smd pin header". Example
  • \$\begingroup\$ Perhaps you're looking for pogo pins? (Also here.)They generally require that you build a custom fixture to align and clamp the PCB to the pins. \$\endgroup\$ – Dave Tweed Jan 7 '16 at 19:44
