I'm in the process of designing a PCB/Prototype and looking at different types of board-to-wire type connectors. In particular, I want to connect an SPI OLED display to the main PCB. It needs to be removable and small, but not too small that it's delicate/fragile. It also needs to be a low-profile connector since the display and PCB are packaged closed to each other.
Here's the underside of the housing. The main PCB will be within the housing just beneath the display:
Is there another name or trade-name for these type of parts that I should be searching for?
Should I look at standard .1" header pitch for connectors or is there a smaller, yet still common pitch that is still robust and inexpensive?
Also, is this the correct way to connect the display to the pcb for this application?
update: I looking for low profile type connector like this(not not as small and with 7 connectors:
