While trying to minimize the number of NAND gates for realizing EXOR function, \$A\overline{B} \ \cup \ \overline{A} B\$,
I used De Morgan's & got the expression \$\overline{\overline{\left ( A\overline{B} \right )}\cdot \overline{\left ( \overline{A} B \right )}}\$ and hence ended up with \$5\$ NAND Gates. But my book shows it can be done with \$4\$ Gates only.
What should be a good approach towards this minimization problem?
Should I avoid using De Morgan's Law here?
  • \$\begingroup\$ It can be done by 4. But it's a weird simplification. \$\endgroup\$ Jan 9, 2016 at 21:19
  • \$\begingroup\$ Can we reduce 5 gate circuit to a 4 circuit directly or it requires re-simplification from scratch? \$\endgroup\$
    – Romy
    Jan 9, 2016 at 21:22
  • \$\begingroup\$ I did once derive it, and from what I remember it was a bit convoluted - I think it requires making it far less simple first but it was about 5 years ago when I studied it, so can't remember off the top of my head. \$\endgroup\$ Jan 9, 2016 at 21:51
The 4-gate implementation of the XOR function requires the output of one of the gates to be used twice. As far as I know, there's no direct algorithmic way to come up with such solutions; they must be "discovered".
In a sense, you have to "de-optimize" the solution before optimizing it, and knowing what deoptimization step makes sense is a matter of intuition. In this case, it requires the observation* that
$$A\cdot\overline{B} = A\cdot\overline{(A\cdot B)}$$
and
$$\overline{A}\cdot B = \overline{(A\cdot B)}\cdot B$$
and then realizing that the \$\overline{(A\cdot B)}\$ term for both right-hand expressions can be generated by the same gate.
*The details:
Since \$A\cdot\overline{A} = 0\$, you can add this term to any expression without changing it:
$$A\cdot\overline{B} = A\cdot\overline{A} + A\cdot\overline{B}$$
Now, factor out the A
$$\ldots = A\cdot(\overline{A} + \overline{B})$$
and apply DeMorgan's:
$$\ldots = A\cdot\overline{(A\cdot B)}$$
