How should I wire 2 transformers in series (either primaries or secondaries)(not sure which I should use) using a NEMA L14-30 plug from a generator socket? I'm using 2 Microwave Oven Transformers to make a homemade stick welder. I was thinking about using a shared neutral for both.
Questions:
1)Is this a good configuration? (Generator/Shared Neutral)
2)If it is, should I wire the primaries or secondaries in series, and what advantages (or much more likely disadvantages) will be involved in either choice?
3) Can you show/describe the best (or at least a recommended) approach for doing this off of this type of plug?
