A fuse is a sacrificial device. That means,it does it's job and die ( fuse's tiny wire break ). Fuse's job it to prevent High Current to flow in the circuit and hence allow user to operate their devices safely and protect the device itself. Because wire may burn in High Current. (and What not, you may accidentally touch it. )
Most Common reason for breaking Fuse Wire ?
' Short circuits, overloading, mismatched loads, or device failure are the prime reasons for excessive current. '
I think for your case, " It is overloading."
What You can Do ?
Buy A Higher Rating fuse ( not recommended ) " Until you are completely sure operating current is safe "
Or it something wrong in your wiring, get it fixed.
