Hi I am from computer science background and hence lack any solid foundation in electronics. I am trying to learn some flip flop conversions. Most of them are their online, however I did not found below two. So I made them myselves. But I need to know if I prepared the correct?
SR flipflop to T flipflop
T flipflop to SR flipflop
Are above conversions correct?
  • \$\begingroup\$ There are a good number of logic sims out there for free. Might want to check those out in case you have similar questions. \$\endgroup\$
    – Hexum064
    Jan 13, 2016 at 21:55
  • \$\begingroup\$ but are the above correct? \$\endgroup\$
    – Mahesha999
    Jan 13, 2016 at 21:58
Simply put - Yes, your schematics and tables are correct.
*Side note, you can find examples of these anywhere on the net as this is a typical study for undergrad elctrical engineering majors.
