My RC car controller (transmitter) has only 4 buttons (left wheel forward /backward, same for right)
I want to implement a joystick using Arduino.
The Arduino will use PWM on the transmitter circuit, and will use four transistors as emulated button. (When I activate the transistor, the transmitter will think the button is activated.)
  • Do you think it's possible?
  • Do you think it is safe for the transmitter ?
  • Is arduino pwm to fast for the transmitter? do I have to make my own slower version of PWM?
Here are some photo of the transmitter:
  • \$\begingroup\$ This will probably work poorly, as the bandwidth will be low meaning a very low PWM rate. Instead, consider putting a mini-Arduino with something like an NRF24L01+ module (or whatever 2.4 GHz chip you prefer) in the transmitter, and put another in the car, which (apart from better antennas) is what a number of hobby-grade systems use. You may be able to tap into the existing H-bridge and drive that for the motor, though for proportional steering you might want to add a cheap hobby servo or even create one by adding a feedback potentiometer to the typical motor-which-stalls steering. \$\endgroup\$ – Chris Stratton Jan 14 '16 at 4:42
Transistors might work if all the switches connect the inputs to common negative.
If the switches connect one pin of the chip to another then you may have more difficulty. You'll need to trace out the PCB tracks.
Your micro will have to share the COM (-) with the RC battery negative.
It should work.
| improve this answer | |
  • \$\begingroup\$ Yes fortunately it's the case :) Sorry about capitalisation \$\endgroup\$ – n0tis Jan 13 '16 at 21:51
