Most of these strips are laid out in a repeating pattern of three LEDs and their current-limiting resistors along a flexible circuit. There will be scissors marks every 10 cm or so.
Figure 1. Cut along the dotted line.
If it's this type of strip then the LEDs are effectively wired in series parallel along the length of the strip. You can connect the strips end to end but it should be clear from the schematic that you're actually connecting the individual strings of LEDs in parallel.
If you daisy-chain the strips then be aware that the first strip has to carry the current for all the downstream LEDs and the copper may overheat. You've no data sheet so you need to get a feel for what's normal temperature with one strip and add another, etc., until you feel it's getting too hot.
Alternatively wire each strip individually back to the PSU.
If you have a multimeter switch it to 10A DC and plug the red lead into the 10 A socket. Measure the current drawn by one string and work out how many strings your PSU can handle.
Update
The photo arrived after this post. Basic principle still stands but I can see a resistor per LED and the LEDs have six pins. You'll have to figure it out.
Calculating current requirement
Figure 2. Measuring LED strip current.
Hook up a multimeter as shown in Figure 2. and measure the current drawn by one strip. If using a digital multimeter then be sure to plug the red lead into the 10 A socket, and switch to 10 A range before powering up. The total amps will be the sum of all the individual amps readings.
Converting to watts
Let's say you measure 0.9 A. Power for that strip will be given by \$P = V \cdot I = 12 \cdot 0.9 = 10.8 W\$. You can then figure out how many of these strips you can power from a PSU of known wattage.
Your flashing LEDs indicate the power supply has shutdown - probably its thermal protection kicking in.
Plug your red lead back into the V socket before you finish. If you forget and hook it up to a battery, etc., a high current will flow, blow the internal fuse and possibly damage the internal shunt resistor.
