I'm programming a MSP430 in C language as a simulation of real microcontroller. I got stuck in addressing modes (https://en.wikipedia.org/wiki/TI_MSP430#MSP430_CPU), especially:
  • Addressing modes using R0 (PC)
  • Addressing modes using R2 (SR) and R3 (CG), special-case decoding
    1. I don't understand what does mean 0(PC), 2(SR) and 3(CG). What they are?
    2. How to check these values?
  • \$\begingroup\$ The Wiki article explains : R0(PC) is the program counter, R1(SP) the stack pointer, R2(SR) the status register(carry flag, and power saving modes) - and R3 (CG) generates constant values without requiring the space they would require as literal values. As these are register addresses, not modes, I can't really understand what you're asking. Perhaps explain a bit more what you don't understand? \$\endgroup\$ – Brian Drummond Jan 14 '16 at 0:03
  • \$\begingroup\$ Do I understand correctly that you are trying to write an MSP430 Emulator in C? \$\endgroup\$ – brhans Jan 14 '16 at 0:25
  • \$\begingroup\$ Duplicate of same question on Stack Overflow. \$\endgroup\$ – CL. Jan 14 '16 at 7:41
so for the source if the as bits are 01 and the source register bits are a 0 which is the pc for reference then
ADDR Symbolic. Equivalent to x(PC). The operand is in memory at address PC+x.
if the ad bit is a 1 and the destination is a 0 then also
x is going to be another word that follows this instruction so the cpu will fetch the next word, add it to the pc and that is the source
if the as bits are 11 and the source is register 0, the source is an immediate value which is in the next word after the instruction.
if the as bits are 01 and the source is a 2 which happens to be the SR register for reference then the address is x the next word after the instruction (&ADDR)
if the ad bit is a 1 and the destination register is a 2 then it is also an &ADDR
if the as bits are 10 the source bits are a 2, then the source is the constant value 4 and we dont have to burn a word in flash after the instruction for that 4.
it doesnt make sense to have a destination be a constant 4 so that isnt a real combination.
repeat for the rest of the table.
you can have both of these addressing modes at the same time
mov #0x5A80,&0x0120
generates
c000:   b2 40 80 5a     mov #23168, &0x0120 ;#0x5a80
c004:   20 01
which is
0x40b2 0x5a80 0x0120
0100000010110010
0100 opcode mov
0000 source
1 ad
0 b/w
11 as
0010 destination
so we have an as of 11 with source of 0 the immediate #x, an ad of 1 with a destination 2 so the destination is &ADDR. this is an important experiment because when you have 2 x values, a three word instruction basically which one goes with the source and which the destination
so the address 0x5a80 which is the destination is the first x to follow the instruction then the source 0x0120 an immediate comes after that.
if it were just an immediate and a register then
c006:   31 40 ff 03     mov #1023,  r1  ;#0x03ff
0x4031 0x03FF
0100000000110001
0100 mov
0000 source
0 ad
0 b/w
11 as
0001 dest
as of 11 and source of 0 is #immediate the X is 0x03FF in this case the word that follows. the destination is ad of 0
Register direct. The operand is the contents of Rn
where destination in this case is r1
so the first group Rn, x(Rn), @Rn and @Rn+ are the normal cases, the ones below that that you are asking about are special cases, if you get a combination that fits into a special case then you do that otherwise you do the normal case like the mov immediate to r1 example above. the destination of r1 was a normal Rn case.
