I am struggling in trying to put a UART Port working (no flow control and no parity bit) in a PIC32MX in order to comunicate with a Fingerprint for too long, so I decided to get back to you guys. I just can put the fingerprint reader in digital I/O's because I have no more UART PORTs available. There's no problem for the TX pin but when it comes to enable RX pin (CN interrupt) I am seeing a problem.
This is the Fingerprint Reader I am using an this is the datasheet for the PIC.
I am using the CN4/RB2 Port for the Interrupt (Rx) and the RB0 to transmit. The compiler is XC32.
#include "NVMem.h"
#define Baudrate        4800   //bps
#define OneBitDelay     (1000000/Baudrate)  // microseconds
#define DataBitCount          8             // no parity, no flow control
#define UART_RX               TRISBbits.TRISB2  // UART RX pin
#define UART_TX               LATBbits.LATB0    // UART TX pin
#define UART_RX_DIR           TRISBbits.TRISB2 // UART RX pin direction
#define UART_TX_DIR           TRISBbits.TRISB0 // UART TX pin direction
int volatile readB = 0;
unsigned char UART_Receive(void);
void UART_Transmit(const char);
void __ISR(_CHANGE_NOTICE_VECTOR, ipl5) ChangeNoticeHandler(void)
readB = PORTB;      // Read PORTB to clear CN4 mismatch condition
if (readB){
    UART_Transmit(UART_Receive());
LATDINV = 0x0F;     // PORTG = 0xff;    // Toggle outputs.
IFS1CLR = 0x0001;   // Be sure to clear the CN interrupt status
unsigned char DataValue = 0;
    unsigned char i = 0;
while(UART_RX==1);
delay_us(OneBitDelay);
delay_us(OneBitDelay/2);
for (  i = 0; i < DataBitCount; i++ )
    if ( UART_RX == 1 )   //if received bit is high
        DataValue += (1<<i);
if ( UART_RX == 1 )       //Stop bit should be high
        return DataValue;
else                      //some error occurred !
        return 0x000;
void UART_Transmit(const char DataValue)
/* Basic Logic
   TX pin is usually high. A high to low bit is the starting bit and
   a low to high bit is the ending bit. No parity bit. No flow control.
   BitCount is the number of bits to transmit. Data is transmitted LSB     first.
// Send Start Bit
UART_TX = 0;
unsigned char i;
    //Set Data pin according to the DataValue
    if( ((DataValue>>i)&0x1) == 0x1 )   //if Bit is high
        UART_TX = 1;
    else      //if Bit is low
        UART_TX = 0;
//Send Stop Bit
UART_TX = 1;
void FingerprintRun(Task * task){
 CNCON = 0x8000;                 // Enable CN module
 CNEN = 0x00000010; // Enable individual CN pin CN4
 CNPUE = 0x00000010; // Enable weak pull up for pin CN4
 UART_TX = 1;           // TX pin is high in idle state
 UART_RX_DIR = 1;       // Input
 UART_TX_DIR = 0;       // Output
 readB = PORTB;
 IPC6SET = 0x00140000; // Set priority level=5
 IPC6SET = 0x00030000; // Set Subpriority level=3
 IEC1SET = 0x0001; // Enable Change Notice interrupts
UART_Transmit ('H');
UART_Transmit ('i');
UART_Transmit ('\r');
while(UART_RX==0){
    asm("nop");
while(1)
While debugging the Program Counter never goes to the interrupt.
  • \$\begingroup\$ usually you use an RX char interrupt source from the UART module rather than individual pin interrupt. Also see this question: electronics.stackexchange.com/questions/135638/… \$\endgroup\$
    – Icy
    Jan 14, 2016 at 15:37
  • \$\begingroup\$ Well I am not using the RX interrupt source from the UART module because I have no more available. Not only this, I have no PPS (peripheral pin select) in this Pic. I am reusing an old design. \$\endgroup\$
    – scuba
    Jan 14, 2016 at 15:41
  • \$\begingroup\$ Don't understand? Why no more available? \$\endgroup\$
    – Icy
    Jan 14, 2016 at 15:43
    \$\begingroup\$ @Icy I think he's trying to bit-bang a 'software UART', but I don't see any attempt to read or write bits at any particular baud-rate - no delays or timing anywhere in the code ... \$\endgroup\$
    – brhans
    Jan 14, 2016 at 15:55
    \$\begingroup\$ I don't think there are ready-made delay_us/delay_ms functions in XC32 for the PIC32. microchip.com/forums/m769139.aspx has some info on writing your own. \$\endgroup\$
    – brhans
    Jan 14, 2016 at 16:26
your line: CNEN = 0x00000010; // Enable individual CN pin CN4
should be: CNEN = 0x00010000; // Enable individual CN pin CN4
and similar for CNPUE
You also need to implement timing in your software as per @brhans comments
Using delays in your interrupt routine is not be good practice - the CPU will not be able to do any other processing - including responding to other interrupts, in the time it takes to read each character, much better to start a timer and sample the port bit on that timers interrupt.
  • \$\begingroup\$ So can you give me a brief explanation of how to use the timer in this case. \$\endgroup\$
    – scuba
    Jan 14, 2016 at 16:57
