What method do people generally use to represent socketed components in a schematic, notably in this case I am referring to resistors & capacitors mounted into machined socket pins (multiple into the same strip).
There are three immediately obvious approaches but neither seem to well capture the intent, or lend themselves very poorly to reuse.
Draw the parts as usual, select a footprint certain footprint (0.4" Spacing in my case) that matches the socket. Then when laying out a PCB ensure all of these separate parts are correctly located.
This feels like a pretty poor solution in that the sockets will not show up in your bom and there is a lot of points for potential error
Insert a component into your schematic for the socket, and comment in the schematic what goes into it.
This seems poor as it greatly reduces the readability of the schematic.
Create a custom multi part component with each part having their own symbol (resistor in a dotted box or something), and link this to your footprint.
This method seems relatively foolproof but means a large number of one off components will be generated with minimal chance or re-use.
Presumably this isn't that uncommon a task, as it is seen fairly regularly in industrial electronics, how is this usually presented.
