On my design, a TO228 mosfet will conduct much power. Under it, I put two Fills (one on top and one on bottom layer). I plan to link them with vias in order to conduct better power and to user the bottom one for thermal dissipation.
With altium, I added a via stitching on these fills. I also checked the option "Allow vias under SMD pads" in design rules.
The issue is that stiching is not applyed when under the pad of the mosfet. The option "allow vias under SMD" does not seem to affect via stitching.
I saw on other components design that those vias are added in the component own design.
I would preferably add the vias if I assume it is needed and only. I mean at board design time. Is there a way to ?
Thanks
