-1
Is there any transistor that can be used to switch voltages up to 3000 volts? What transistor could it be?
closed as off-topic by Ignacio Vazquez-Abrams, AaronD, helloworld922, PeterJ, Dave Tweed Jan 16 '16 at 13:39
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
There are power transistors available in market,I dont think so that,It's voltage rating will be around 3000V. However,there are transistors,which will tolerate upto 1500V. Check out this page STM high voltage transistor.
    You can use relays for switching high voltages.There are relays available in market,which are rated at maximum wattage.I think,relays will be suitable for switching application
