I have a SharkX6 flight controller (FC) that I am using in a quadcopter that I am building. The flight controller came with a broken (the fried IC is to the left of the '100' component) power distribution board (see attached image). This board besides providing +5V to the FC (via a voltage regulator circuit) and power to the ESCs, also provides a USB circuit for connecting the flight controller to the PC via a MicroUSB port. The USB circuit in the power distribution board takes 4 USB lines (VCC/5V, DATA+, DATA- and GND) and outputs two lines marked U+ and U- that go to the FC USB pins. The USB circuit is shown with the blue arrow in the picture. On the right of the board BLACK is VCC, WHITE is D+, RED is D- and ORANGE is GND.
The power distribution board picture is here: enter image description here
Using a (borrowed) working power distribution board, when connected to the PC I verified that my FC is correctly recognized by the PC, so the FC USB connection port works. The problem I have is that I have to somehow create a cable or circuit to replicate this function because the power distribution board is not available for sale and I would like to be able to connect my FC to my computer and change it's parameters.
My question is: is there some ready-made or easy to understand and build circuit that would allow me to connect the FC to the PC? I have tried pulling up the D+ line to 3.33V by using the VCC line through a voltage divider without success; the computer does recognize that a USB device is connected but it fails with an unknown descriptor and I get the familiar Windows message for malfunctioning device.
closed as off-topic by Brian Carlton, Daniel Grillo, Bimpelrekkie, Ricardo, Asmyldof Mar 31 '16 at 22:22
This question appears to be off-topic. The users who voted to close gave these specific reasons:
If this question can be reworded to fit the rules in the help center, please edit the question.
Nice picture with enough detail to see useful things.
Looks like the USB data lines are just jumpered (0-ohm resistors) to the U+ U- lines - have you tried that? (along with supplying power as needed) - to be clear don't "pull the data line" anywhere - let the USB device (flight controller) you are connecting to do that. USB power should not be very much (if at all) involved here since there's a power supply already going on.
  • \$\begingroup\$ Thanks for the answer. Yes, "jumpering" D+ D- with U+ and U- respectively was the first thing I did without success (the computer does not detect the USB device at all).Using a voltometer, I measured U+ and U- from the working power board and it is +3.74V. The broken board performs the same but the Windows "unrecognized/malfunctioning" message appears. \$\endgroup\$ – Frontier Jan 18 '16 at 15:11
You didn't say if +5V is working on the board. I have a similar problem with a quad I bought that didn't work. In my case, the 100 component was separated from the board, and wouldn't supply power. I bridged it back, and the quad woke up. But its USB doesn't work. Mine is from a Flying 3D X8, which is similar, but components are in different locations.
  • \$\begingroup\$ In my case the problem relies with the step-down module - the 8-pin IC to the left of the '100' component - which is damaged. By supplying 5V - via an external step-down module - to the DC input lines, the USB connection worked. \$\endgroup\$ – Frontier Apr 1 '16 at 17:59
