I'm working on a design that uses a WWVB antenna receiver....
The WWVB antenna is a small (~ 1/4" x 4" rod). Size is not a constraint so I could make it much bigger if a I half to.
The design is powered by AC/DC converter w/ SMPS. Its an unenclosed module I got off digikey. Whenever the Supply is on and near by the antenna receiver cannot pick up a signal.
The antenna & Powersupply have to be able to operate together in a small enclosure. How can a shield the Antenna from the noise?
Design a receiver that has better filter?
Use ferrite RF shielding sheets?
Design a larger antenna?
Position the Powersupply so that it emits noise perpendicular to the antenna's sensitive direction?
Thanks
