I am working with this library.
This library uses DMA1 channel 2,5,7 but these channels are required by USART. So I have changed the channels and corresponding to timers ( totimer2 and to timer4).
Also the library uses GPIOA, GPIOA pins not fully available for full drive (work with 16 channel), so I have changed GPIOA to GPIOB. After these changes the code worked well, but I realized after a week that some rows(channel 13,12,10,3, etc. )do not work.
I'm sure all GPIOB pins are works as digital I/O. I have check them, but DMA operation can't drive the GPIOB. I don't understand why.
After WS2812_sendbuf
command, the state of these pins go from low to high and stay there forever. Not falling back to low, only if I reset them manually. So the problem is that the DMA does not clear them.
My MCU is an STM32f103C8T6 @72Mhz.
My Code:
/*my code*/
#define WS2812_DEADPERIOD 19
uint16_t WS2812_IO_High = 0xFFFF;
uint16_t WS2812_IO_Low = 0x0000;
volatile uint8_t WS2812_TC = 1;
volatile uint8_t TIM4_overflows = 0;
uint16_t WS2812_IO_framedata[6144]; //WS2812 framebuffer buffersize = (#LEDs / 16) * 24 //for 256 leds
uint8_t allow_update=0;
void GPIOB_init(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_NoJTRST, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
GPIO_InitStructure.GPIO_Pin = 0xFFFF;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
void TIM4_init(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
uint16_t PrescalerValue;
// TIM4 Periph clock enable
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 29; // 800kHz
TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
TIM_ARRPreloadConfig(TIM4, DISABLE);
/* Timing Mode configuration: Channel 1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
TIM_OCInitStructure.TIM_Pulse = 8;
TIM_OC1Init(TIM4, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Disable);
/* Timing Mode configuration: Channel 2 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_Pulse = 17;
TIM_OC2Init(TIM4, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Disable);
/* configure TIM4 interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void WS2812_sendbuf(uint32_t buffersize)
// transmission complete flag, indicate that transmission is taking place
WS2812_TC = 0;
// clear all relevant DMA flags
DMA_ClearFlag(DMA1_FLAG_TC7 | DMA1_FLAG_HT7 | DMA1_FLAG_GL7 | DMA1_FLAG_TE7);
DMA_ClearFlag(DMA1_FLAG_TC1 | DMA1_FLAG_HT1 | DMA1_FLAG_GL1 | DMA1_FLAG_TE1);
DMA_ClearFlag(DMA1_FLAG_HT4 | DMA1_FLAG_GL4 | DMA1_FLAG_TE4);
// configure the number of bytes to be transferred by the DMA controller
DMA_SetCurrDataCounter(DMA1_Channel7, buffersize); //dma channel 2 --> 7
DMA_SetCurrDataCounter(DMA1_Channel1, buffersize); //dma channel 5 --> 1
DMA_SetCurrDataCounter(DMA1_Channel4, buffersize); //dma channel 7 --> 4
// clear all TIM4 flags
TIM4->SR = 0;
// enable the corresponding DMA channels
DMA_Cmd(DMA1_Channel7, ENABLE);
DMA_Cmd(DMA1_Channel1, ENABLE);
DMA_Cmd(DMA1_Channel4, ENABLE);
// IMPORTANT: enable the TIM4 DMA requests AFTER enabling the DMA channels!
TIM_DMACmd(TIM4, TIM_DMA_CC1, ENABLE);
TIM_DMACmd(TIM4, TIM_DMA_CC2, ENABLE);
TIM_DMACmd(TIM4, TIM_DMA_Update, ENABLE);
// preload counter with 29 so TIM4 generates UEV directly to start DMA transfer
TIM_SetCounter(TIM4, 29);
// start TIM4
TIM_Cmd(TIM4, ENABLE);
/* DMA1 Channel7 Interrupt Handler gets executed once the complete framebuffer has been transmitted to the LEDs */
void DMA1_Channel4_IRQHandler(void)
// clear DMA7 transfer complete interrupt flag
DMA_ClearITPendingBit(DMA1_IT_TC4);
// enable TIM4 Update interrupt to append 50us dead period
TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
// disable the DMA channels
DMA_Cmd(DMA1_Channel7, DISABLE);
DMA_Cmd(DMA1_Channel1, DISABLE);
DMA_Cmd(DMA1_Channel4, DISABLE);
// IMPORTANT: disable the DMA requests, too!
TIM_DMACmd(TIM4, TIM_DMA_CC1, DISABLE);
TIM_DMACmd(TIM4, TIM_DMA_CC2, DISABLE);
TIM_DMACmd(TIM4, TIM_DMA_Update, DISABLE);
/* TIM4 Interrupt Handler gets executed on every TIM4 Update if enabled */
void TIM4_IRQHandler(void)
// Clear TIM4 Interrupt Flag
TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
if (TIM4_overflows < (uint8_t)WS2812_DEADPERIOD)
// count the number of occured overflows
TIM4_overflows++;
else
// clear the number of overflows
TIM4_overflows = 0;
// stop TIM4 now because dead period has been reached
TIM_Cmd(TIM4, DISABLE);
TIM_ITConfig(TIM4, TIM_IT_Update, DISABLE);
// finally indicate that the data frame has been transmitted
WS2812_TC = 1;
void WS2812_framedata_setPixel(uint8_t row, uint16_t column, uint8_t red, uint8_t green, uint8_t blue)
uint8_t i;
for (i = 0; i < 8; i++)
// clear the data for pixel
WS2812_IO_framedata[((column*24)+i)] &= ~(0x01<<row);
WS2812_IO_framedata[((column*24)+8+i)] &= ~(0x01<<row);
WS2812_IO_framedata[((column*24)+16+i)] &= ~(0x01<<row);
// write new data for pixel
WS2812_IO_framedata[((column*24)+i)] |= ((((green<<i) & 0x80)>>7)<<row);
WS2812_IO_framedata[((column*24)+8+i)] |= ((((red<<i) & 0x80)>>7)<<row);
WS2812_IO_framedata[((column*24)+16+i)] |= ((((blue<<i) & 0x80)>>7)<<row);
void DMA_init(void) //port b için
DMA_InitTypeDef DMA_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
// TIM4 Update event
/* DMA1 Channel2 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel7);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&GPIOB->ODR;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)WS2812_IO_High;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = 0;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel7, &DMA_InitStructure);
// TIM4 CC1 event
/* DMA1 Channel1 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)WS2812_IO_framedata;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
// TIM4 CC2 event
/* DMA1 Channel7 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel4);
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)WS2812_IO_Low;
DMA_Init(DMA1_Channel4, &DMA_InitStructure);
/* configure DMA1 Channel7 interrupt */
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
/* enable DMA1 Channel7 transfer complete interrupt */
DMA_ITConfig(DMA1_Channel4, DMA_IT_TC, ENABLE);
uint8_t Get_WS2812_TC()
return WS2812_TC;
void WS2812B_Init()
GPIOB_init();
DMA_init();
TIM4_init();
Update:
Finally I found the bug in the library.
wrong:
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)WS2812_IO_High; //("&" mistaked)
right:
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&WS2812_IO_High;
