In a circuit with a voltage source in series with a capacitor, inductor, and resistor, will the complex power of the capacitor and inductor be in phase?
In calculating Sc and Sl I see that the phase angles are approximately the same ~ -27.5 deg. Is this intuitively possible or did I make a calculation mistake?
Thanks![enter image description here]1
  • \$\begingroup\$ Your capacitive reactance has a much higher magnitude than your inductive reactance in your calculations. \$\endgroup\$ Jan 18, 2016 at 5:45
No they won't. If you just consider the simpler circuit of a source with a parallel capacitor and parallel inductor i.e. no series resistor, the current flow in the capacitor is exactly 180 degrees opposite to the current flow in the inductor.
Adding the resistor makes things a little less than 180 degrees and, if the resistor totally dominated that limb impedance wise then the best you would see is a 90 degree difference between capacitor current and "the other current".
For my definition of complex power I've used this wiki article.
