6
I have been working with STM32 series ARM microcontrollers on IAR Embedded Workbench for a while. For some reasons, now I need to move my works to Qt-Creator (both on Windows and Linux). In IAR EWARM, things are simpler: I've never had to deal with linker scripts or startup files, just open an IAR EWARM project template from ST's Peripheral Library release and with some simple adjustments, it's ready. Anyway, I tried to create a new project for STM32F4 on Qt but I faced with various problems.
Is there anybody that can explain this process clearly, step-by-step? With the related makefile, linker script, startup and system files if possible.
Note: Actually, I have a bunch of specific questions about the issue, but since I think that an explanation of the whole process may be helpful for me as well as other embedded newbies, I decided to ask the question this way.
  • \$\begingroup\$ What do you call "Qt environment" ? You mean the use of Qt-Creator ? Or you want your program to run in a Qt application ? Or you mean to run a Qt based program on STM32 ? It is not clear to me.. \$\endgroup\$
    – Antoine
    Jan 18, 2016 at 14:59
  • \$\begingroup\$ I want to compile my C code on Qt-Creator and download it to the mCU. I edited the question. \$\endgroup\$
    – ddyn
    Jan 18, 2016 at 15:40
    \$\begingroup\$ I don't think it is such a great idea. It will be lot of pain for a tool that doesn't fit really the need. Why don't you go for something like CooCox or GNU ARM Eclipse ? \$\endgroup\$
    – Antoine
    Jan 18, 2016 at 16:04
    \$\begingroup\$ Or if you don't like eclipse based IDEs, try CodeBlocks. It has a nice Embedded toolchain support. \$\endgroup\$
    – Antoine
    Jan 18, 2016 at 16:34
  • \$\begingroup\$ @Antoine , Qt is the only option at work for now. But I'll definitely try CodeBlocks at home, thank you. \$\endgroup\$
    – ddyn
    Jan 19, 2016 at 8:07
4 Answers 4
9
I actually work with this setup, it works wonderful.
First make sure you use a recent Qt Creator version. I downloaded mine from the website. In some Linux repositories it is outdated and does not support the BareMetal plugin, and/or QBS (which is quite useful).
Requisites:
  • Qt Creator (download from QT site)
  • ARM GCC (Ubuntu: apt-get install gcc-arm-none-eabi)
  • GDB source archive (download from archive)
  • OpenOCD (Ubuntu: apt-get install openocd)
Versions used: Qt Creator 3.6.0, ARM GCC 4.8.2-14ubuntu1+6, ARM GDB 7.6/7.10 with python support and OpenOCD 0.7.0.
1) Install Qt Creator. Open Help -> About Plugins. Find category Device Support and check BareMetal.
2) Go to Tools -> Options. There are a few settings we need to create and adjust in order to compile for an ARM Cortex controller.
a) Go to "Bare Metal" (last category) - add a debugger of your choice. I personally use OpenOCD. At this point you can set the connection to gdb and it's port, as well as init commands. The standard commands are set for STM32F4xx chips - but I guess you can modify it to work with any ARM Cortex controller.
b) Go to "Devices". Add a new device, choose Bare Metal and the GDB provider you have just created. There is nothing else to setup here.
c) Go to "Build & Run" - tab Debuggers. This has been the most trickiest thing to do.
You need an arm gdb version with python scripting support. At the time (about 9 months back when I write this post) the binaries in Ubuntu repo does not have this option. You can save a lot of time/hassle by checking if this has changed.
Nevertheless if you do need to compile GDB with python supporet, here is how to do it. Download GDB from the download archives. I still use GDB-7.6 which seems to work fine, but for this tutorial I have recompiled it for GDB-7.10.
Extract the source archive. Open in terminal and run "./configure --with-python --target=arm-elf". This sets up the make environment for ARM targets with python scripting enabled. Then run make. This takes a while, depending on your system speed. Unfortunately you may be a bit on your own once the compilation stops because of dependency issues. Don't be afraid - this happened to me on my first try too and I figured it out with a bunch of google searches! If python fails, make sure to install the python2.x-dev package (check your version no - likely 2.7). Assuming compilation went well, you can find the gdb executable in the main directory.
If you're on Mac, the process will likely be similar. But I am not familiar with OSX. If you're on Windows, sorry you will need to google a bit on how to do this with Mingw or whatever (honestly I don't know). Or maybe find binaries that have this support enabled.
Once you acquired a gdb executable, call it e.g. "ARM GDB" and set the path to it. I personally don't bother to place it in /usr/bin/, but I guess you could.
This window will throw an error if you use a gdb executable that is not compiled with Python Scripting.
d) Tab "Build & Run" - "Compilers"
Create a new "GCC compiler" and call it "ARM GCC". For path use "/usr/bin/arm-none-eabi-gcc". The "ABI" is not really important, I have just set it to arm-unknown-unknown-unknown-32bit.
e) Tab "Build & Run" - "Kits". Add a new kit, I called mine "ARM Bare Metal". Device type: "Bare Metal" Device: point to the Device you have created with it's OpenOCD/St link GDB server Sysroot: leave it empty Compiler: ARM GCC Debugger: ARM GDB Qt Version: None - You obviously cannot run the QT runtime on a Cortex m4! Cmake tool: unused
Make sure there are no warnings in any of the Build & Run tab
3) Make your make/qmake/QBS project. On left side go to tab "projects" and at left-top add the "ARM Bare Metal" kit. This should work without errors. Your project may start out with a desktop kit. Replacing usually does not work. In that case add an ARM kit and then remove the desktop one.
4) Start your OpenOcd server. I use a STM32F4 discovery for development, and also off-board programming to my own STM32 boards. For any STM32F40x/STM32F41x targets run:
openocd -f board/stm32f4discovery.cfg
This starts a gdb server at port 3333 and a telnet server (for OpenOCD commands) at 4444. As a shortcut I create a few .sh files in my home directory for a quick startup of a GDB server.
5) Start the debug session. It should program and run!
You can set breakpoints, step through code, even more PC back, watch call stack, variables (locals / watch), and disassembly. I'm really quited please with this, but obviously it lacks a few things like: 1) "Register view". Yes it has one, but that's just the CPU registers. I want register view of my peripherals as well. 2) Download progress or more detailed info about connection state. You need to refer to openocd for this.
edit: I have put up an example project on this Github repository.. It contains this post with a few dialog screenshots added, as well as a blinky project for the STM32F4 Discovery board using a QBS project in Qt Creator.
  • \$\begingroup\$ What exactly do you gain using Qt Creator as a tool chain? \$\endgroup\$
    – Matt Young
    Jan 19, 2016 at 19:13
  • \$\begingroup\$ I think a large share of personal preference. I can appreciate the versatility of Eclipse, but I absolutely cannot stand how slow Java IDE's are. CodeBlocks was mentioned earlier too, I guess there is not much difference. They are both IDE's for C/C++ with GDB debugging. I like QBS build system, but it's not a must. I happen to already use Qt so it's nice to stay within 1 environment for coding. There are probably much better commercial solutions available, but often not cross platform or out of budget for many hobbyists or small teams. \$\endgroup\$
    – Hans
    Jan 19, 2016 at 22:11
  • \$\begingroup\$ I used Qt and Qt Creator for the one desktop application I've ever written, and never in a million years would have thought people were using it for embedded development. Something new every day... \$\endgroup\$
    – Matt Young
    Jan 19, 2016 at 22:26
  • \$\begingroup\$ There are many ways leading to Rome. Any IDE that talks to GDB will be used at some point for cross-platform or embedded development I suppose. Visual Studio can also talk to OpenOCD via the VisualGDB plug-in, and so it can be (is being) used for ARM development. OTOH one could also write a script that runs a Makefile and calls a JTAG cmd line tool to upload their binary image to their board. You could use Vim and debug via serial/scope. No need for any interface or debugger that supports code stepping. If that is what works for you that's fine too right? :-) \$\endgroup\$
    – Hans
    Jan 19, 2016 at 22:51
  • \$\begingroup\$ Thanks for the heads-up about the bareMetal plugin. I remember hearing it mentioned once and then forgot. \$\endgroup\$ Feb 15, 2019 at 22:34
Download and install GCC-ARM, OpenOCD and ST-Util. STM32CubeF4 is optional but mandatory.
Add a custom compiler and debugger as image bellow on Tools->Options->Build & Run.
Learn how to use OpenOCD, GDB and ST-Flash.
Suggested Sites:
Cover all setup of QtCreator
http://www.bartslinger.com/cx-10-quadcopter/debugging-stm32-from-qtcreator/
Simple bare metal project for STM32 (it's mine)
https://vilacoder.wordpress.com/category/arm/
Good starting point for you is wiki.qt.io/Building_Qt_5_from_Git
Also you'll find everything you need in their documentation which is on doc.qt.io.
You'll get the best support on its official forum forum.qt.io/category/4/qt-development.
This is more SO question, and not for SE EE.
  • \$\begingroup\$ Thank you, I will check these out. By the way, I first asked this question on SO and couldn't get an answer for like half an hour, so I decided to ask it here. \$\endgroup\$
    – ddyn
    Jan 18, 2016 at 13:24
  • \$\begingroup\$ Get STM32Cube to generate a project for eclipse tool SW4STM32 .. you get an eclipse project. QT may be able to import this directly, or you could look at the makefile it generates in <yourproject>/Your Proj config>/debug/makefile.. You may have to compile it first to get the makefile generated \$\endgroup\$
    – ChrisR
    Jan 18, 2016 at 14:00
If you want to build Qt targeting STM32, the short answer is : Forget it !
Why ? Qt is meant to run on Windows or Linux as you mention. But is is not possible to run those OS's on a STM32 because it lack a MMU, memory, power, etc..
If you want to port Qt to a new OS or event bare-metal, the road will be very long!
  • \$\begingroup\$ I don't think the original poster wants to port Qt to a microcontroller. Instead, s/he wants to know how how to get a project running using Qt when starting from scratch. The OP is quite clear about using both Windows and Linux. \$\endgroup\$ Jan 18, 2016 at 15:37
  • \$\begingroup\$ The OP does not want Qt on the STM32, they just want to use Qt Creator (the IDE) for STM32 development. \$\endgroup\$
    – Venemo
    May 20, 2017 at 13:14
