I'm planning to make a data logger project with 3-axis sensor and SD card. I would like to store 3200 samples per every second on SD card. Currently I could able to store only 630 samples per second.
Someone told me writing in binary format is the solution.
Then I did accordingly.
fwrite(readings,sizeof(int16_t),6,logFile);
I can see .bin file with more data size compared to .txt or printf.
How can I get the readable ASCII format from .bin file?
I tried by using fread.
FILE *logFile = fopen(fileName,"rb");
int readings[6];
nr = fread(readings,sizeof(int16_t),6,logFile);
How can I see the readable ASCII data?.
Thank you.
    \$\begingroup\$ What library are you using? This isnt code from the Arduino SD library. Edit your post and show the rest of your code \$\endgroup\$ – SoreDakeNoKoto Jan 19 '16 at 11:45
    \$\begingroup\$ You may want to change the title of your question. You ask about reading binary data from a .bin file, not writing data to a sd-card, as this works already (as I have understood). \$\endgroup\$ – jwsc Jan 19 '16 at 12:22
  • \$\begingroup\$ regarding the writing of the data to the sd-card. If you buffer the data in memory, (for instance, have a buffer that is large enough to hold 1 second of data) read the data from the sensor into the 'appropriate' location(s) in the buffer. then, switch to a second buffer for reading the data while writing the first buffer to the sd-card, then when the second buffer is full, switch back to the first buffer for input (I.E. use double buffering) then the throughput will be massively increased \$\endgroup\$ – user3629249 Jan 19 '16 at 15:29
how can I see the readable ASCII data?
use something similar to:
printf( "\n");
for( int i=0; i<6; i++)
    printf("%d ", readings[i]);
| improve this answer | |
