7
I wonder why octagonal IC packages in the LQFP times have never been a thing.
In my opinion they would allow easier pcb routing, they take less space and weight for the same die size, shorter leads to the die compared to square packages as well.
Pick and place machines wouldn't have a problem with them, and EDA software is fine with 45° routing anyway, so it seems like a logical thing to do.
Yet I've never seen one.
Any idea why?
    \$\begingroup\$ people skipped them right away to go to bga \$\endgroup\$
    – PlasmaHH
    Commented Jan 19, 2016 at 20:46
    \$\begingroup\$ One look at the prototype and they were a no-go \$\endgroup\$ Commented Jan 19, 2016 at 20:48
  • 4
    \$\begingroup\$ At 2x the number of edges, there'd be a shortage of IC package edges. \$\endgroup\$ Commented Jan 19, 2016 at 20:49
  • \$\begingroup\$ I bet that there's a lower tolerance for angular misalignment \$\endgroup\$ Commented Jan 19, 2016 at 20:50
  • \$\begingroup\$ Interesting question. In some cases, dice are mounted directly on the PCB. (Chip on board, or COB). Usually the pads are then arrayed in a circle around the die. It may be that when the concerns you mention are important, they go to COB rather than octagonal packaging. \$\endgroup\$
    – user57037
    Commented Jan 19, 2016 at 21:05
4 Answers 4
8
I don't think you'd get any advantage. If you look at a square and an octagon with the same perimeter, the octagon does not look great. On top of the that, you normally lose a bit of space at the corners (compare PLCC and TQFP packages) so I think you'd lose a lot with double the corners.
  • \$\begingroup\$ Would there be any benefit in signal routing (as suggested in the question)? I would guess that in many cases signals are/were not routed in many directions and that more variable trace length might introduce issues. Rectangular dies (a consequence of wafer cutting methods) might also make such packaging less desirable. \$\endgroup\$
    – user15426
    Commented Jan 20, 2016 at 3:16
  • \$\begingroup\$ @PaulA.Clayton As you say, chips are almost always rectangular so I'm not really seeing any advantages- square or almost square packages have the shortest length of leads. Even if packed perfectly, the area of a regular octagon is about 20.7% larger compared to a square of the same perimeter, and usually for PCB layout the square you can inscribe the shape into is more like the space effectively consumed (>45% more PCB area) since it's hard to use the space in the corners. \$\endgroup\$ Commented Jan 20, 2016 at 3:26
  • \$\begingroup\$ I'm not sure if the corners are the problem here... Because the corners of an octagon are less sharp, one also looses less space when placing pins near the edge. And personally I think the octagon looks great! I always like the octagonal coil packages ;) \$\endgroup\$
    – Douwe66
    Commented Jan 20, 2016 at 9:33
I think it would make sense from a PCB designer point of view, however production wise it is not the best idea.
Comparing a square and octagonal TQFP package with the same area, shows that the ammount of pins stays equal without any problems. And surely, routing a PCB could be a lot easier with this!
But, to provide another viewpoint:
The production of octagonal dies is less efficient than for square dies. So if the chip designer wants to make his chip as small as possible, this is not going to help... The die inside the package would still be square to make production cost effective.
And of course, square dies are easily sawn by vertical and horizontal lines, whereas ocotagonal shapes need another cutting method...
  • \$\begingroup\$ OP did not suggest octagonal dies. OP suggested octagonal packaging. \$\endgroup\$
    – user57037
    Commented Jan 21, 2016 at 4:57
  • \$\begingroup\$ But when square dies are mounted in octagonal packages, a lot of space is wasted. \$\endgroup\$
    – Uwe
    Commented Oct 21, 2016 at 7:30
  • 4
    \$\begingroup\$ Have you ever looked up what decapped chips look like? The die is typically much, much smaller than the package already, whether square or octagonal. \$\endgroup\$
    – Hearth
    Commented Apr 22, 2017 at 16:11
Traditionally new packages are developed for better manufacturing yields or higher density. So if there would be any advantage, it would have to be in that primarily. I don't think that manufacturing yield is a reason.. still the same pin technology, pin pitch etc. Density is pins/area -> so a given package should have more pins on it to make sense.
If you consider a square and an octagon with the same overall width/height (e.g. the octagon fits inside the square), you could calculate the perimeter of both packages. I assume the perimeter as a direct indicator of how many pins can fit on a package.
For a rectangle the perimeter is 2*w + 2*h. For an octagon the perimeter is 8 times the length of a side. The length of a side for an octagon is 0.4142*w. (source: wikipedia).
Substitute x=y=1cm, you get 4*1=4cm perimeter for a square and 8*0.4142*1=3.3136cm for an octagonal. That's 17.16% loss in perimeter length, or 17.16% less pins on the same width/height package.
That makes sense, because you're basically "cutting a corner" 4 times. So I can understand why these packages don't exist.
To add a new perspective consider this: modern day ICs often include a lot of digital circuitry. This circuitry is described in a hardware description language which is converted via a toolchain into standard cells, which are connected by an autorouter. These tools are designed for rectangular structures and the geometry is easier in those cases. Also its easier to cut wafers into rectangular pieces, just think of PCBs they are also mostly rectangular. Of course the chips are (mostly) bounded to the package, but still their geometry and relative size matters (differing angles and lengthes of bonding wires).
Additionally you should consider pins close to a vertex, their internal connection would be pretty close to each other (same for squared packages - you do not have pins close to the vertex) and by using an octagonal package, you would increase the relative part of the circumference blocked due to that issue.
In the end I guess they are more complicated to produce for various reasons and give the user little advantage.
