I am trying to figure out if I implemented a 2-1 Mux correctly based on a 3 variable K-map.
my function states F(x,y,z)= Σm(0,1,3,6), and I have created a kmap as follows
  00  01  11 10
0] 1 , 0, 1 , 0
1] 1 , 1 , 0 , 0
Note: the most sig bit is x,and xy are the top inputs and z is the side inputs
from this I found that a 2-1 Mux could be implemented by using z as my selector and ~b=0 and ~a=1, as my inputs to be pushed. Is this correct or have I done this wrong?
Yes,it's right.You can use z as your selector pin.Here's how finally it's look like
If you give z=0,the top portion of K-map will be active.That is 00 and 11,for z=0,the output is 1.
    Similarly when z=1,the output F=1 for x=0 (after some simplifications)
