I am struggling to put my Timer5 working properly. I think I have enabled all the registers but the interrupt never occurs. I already put a break point inside in the FingerprintRun() in the asm("nop") sentence and I found the TMR5 never goes above 0x0000.
void __ISR(_TIMER_5_VECTOR,IPL4) _T5Interrupt(void)
    T5CONbits.ON = 0;
    TMR5 = 0;
    IFS0bits.T5IF = 0;
    UART_TX = 0;
    char x = 'b';
    UARTFingerprintWriteChar( x );
void initTIMER5( void ){
    __asm__("EI");
    INTConfigureSystem(INT_SYSTEM_CONFIG_MULT_VECTOR); //configure multi vector
    INTEnableSystemMultiVectoredInt(); //enable interrupts
    T5CONbits.TON = 0;
    T5CONbits.TGATE = 0;
    T5CONbits.SIDL = 0;
    T5CONbits.TCKPS = 0;// 0b111;1:256 prescale value
    TMR5 = 0;
    PR5=0xD0;
    IFS0bits.T5IF = 0; // Clear timer interrupt flag
    IPC5bits.T5IP = 4; // Setting Timer 5 priority to level 4 of 7
    IPC5bits.T5IS = 1; // setting timer 5 sub priority to level 1 of 3
    IEC0bits.T5IE = 1; // Enable timer interrupts
    T5CONbits.TON = 1;
void main() {
    initTIMER5();
    asm("nop");
    while(1);
Am I missing something?
  • \$\begingroup\$ I upvoted, cheer up! But you need to be more specific, for example I can't see where do you set the counter or increment TMR5. Where do you call FingerprintRun, what is the class Task and more importantly where is your main function? \$\endgroup\$
    – Alper91
    Jan 20 '16 at 21:37
  • \$\begingroup\$ Ok, I will update the code for better understading. Thanks for the tip. @Alperözel the timer should increment by himself, no? I just set TMR5 = 0; \$\endgroup\$
    – scuba
    Jan 20 '16 at 23:32
  • \$\begingroup\$ Insert a while(1); after the asm("nop"); inside the main. The code may be crashing because getting to the end of main is bad. \$\endgroup\$
    – vini_i
    Jan 21 '16 at 0:59
  • \$\begingroup\$ Sorry, I was doing that already. Probably it was a copy-paste problem. \$\endgroup\$
    – scuba
    Jan 21 '16 at 10:48
  • \$\begingroup\$ What is the exact model of you processor? \$\endgroup\$
    – vini_i
    Jan 21 '16 at 11:17
it seems the interrupt is not being enabled (don't know why) so I found another way to make it work.
Instead of: IEC0bits.T5IE = 1; // Enable timer interrupts
I am using: IEC0 = 0x100000;
  • \$\begingroup\$ You might submit this to technical support. Also you may want to use IEC0SET so you dont clear the other bits... \$\endgroup\$
    – Szidor
    Jan 23 '16 at 17:16
