I was playing around with a computer power supply and some resistors and noticed that raising the ohmage decreased the amperage but the voltage was unaffected. Does this mean that voltage is a constant in V=IR. How can you change the voltage with resistors and leave current unaffected.
5\$\begingroup\$ You have just discovered the difference between the "constant voltage power supply" and "constant current power supply". Or simpler put "voltage source" vs "current source". \$\endgroup\$ – Eugene Sh. Jan 21 '16 at 19:13
The voltage was constant because the power supply maintained the voltage (that's its job). In a similar way, if you make a constant current source and pass that current through a variable resistor, then varying the resistance value will change the voltage while the current remains the same.
\$\begingroup\$ what happens if you dont use a constant voltage or amperage power supply? \$\endgroup\$ – Rhezner Jan 21 '16 at 19:27
\$\begingroup\$ Then you don't have constant voltage or amperage. Many weird things might happen. you should be more specific. \$\endgroup\$ – Eugene Sh. Jan 21 '16 at 19:31
1\$\begingroup\$ Then ohms law is followed.For example, if I have a power supply of 10V with a 2 ohm source impedance and I load it with an 8 ohm load, the output of the supply will fall to 8V and 1A will flow. \$\endgroup\$ – user1582568 Jan 21 '16 at 19:32
