I have a solid state relay (pictured below) rated at 24-140 VAC output, and I'd like to use it for digitally controlling a 12 VAC circuit.
SSR 3-8 VDC In/24-140 VAC @ 1 A Out
Will I be able to use this device? In the case that I can't, why not, and what will happen to the SSR?
I would just try it. Maybe you're lucky and it will work for you.
If the manufacturer could guarantee that it would work with 12 V AC on the switched side, I have no doubt that they would put that in the datasheet and print it on the component. But they did not.
So there is no guarantee that it will work. Since the voltage you want to switch is below the rated voltage I see no harm in trying.
The reason why it might not work is that there is a switching element inside, probably a thyristor or a TRIAC. To switch these on properly (with a sharp off-to-on transition) some voltage is needed.
Thyristors and TRIACs only switch off when the current through them becomes zero so that is why this device will only work on AC. If you would switch a DC current, the switch would be on until you remove the current.
    \$\begingroup\$ Try it, it may work for you. But if it does work, it might stop working randomly. Or it might stop working when it's colder or hotter. It might work for some loads and not others. And if you buy another one, of exactly the same type, that may not work, even if the first one did. \$\endgroup\$ – Neil_UK Jan 22 '16 at 9:32
  • \$\begingroup\$ Just to update, it worked no problem. \$\endgroup\$ – Gene Hallman Mar 5 '16 at 20:36
