10
I am interested in the voltage used in electrical fly killers - does anyone know (no speculation please) the voltages generally employed? To be clear, I am talking about mains powered, wall-mounted devices.
I would also be interested in the general topologies used - I am guessing some sort of self-resonant flyback with an unrectified output. Anyone know for sure? I haven't pulled one apart yet...
    \$\begingroup\$ brighthubengineering.com/diy-electronics-devices/… \$\endgroup\$
    – Eugene Sh.
    Jan 22, 2016 at 16:17
    \$\begingroup\$ I have one with a coil directly wired to the plug; 230V (UK mains) \$\endgroup\$ Jan 22, 2016 at 16:21
  • \$\begingroup\$ Thanks @EugeneSh. - I realise I left some critical details out of my original question. Best I can tell from your link is <630Vpk , but useful all the same. Thanks. \$\endgroup\$
    – stefandz
    \$\begingroup\$ I have seen 120V ones and I have seen 1.2kV ones. There is no definite answer - It highly depends on the type and manufacturer. \$\endgroup\$
    – DerStrom8
    Jan 22, 2016 at 16:24
    \$\begingroup\$ Flyback seems appropriate. Will web-apps eventually replace these? \$\endgroup\$
    – Transistor
    Jan 22, 2016 at 16:47
I visited a factory making the 50/60Hz transformer type some years ago. They were several kV (3-4kV) and similar in construction to ballast transformers for neon signs, but without the magnetic shunts to increase the output impedance.
These ones create quite a profound arc which is intended to burn the insect off the grids. Here's a photo of one from Alibaba:
One which I repaired once used rectified 240V mains with a doubler, so about 680V
Here's a teardown video of a cheap plug-in type, which uses voltage doublers to product -630V and +630V across the grid:
https://www.youtube.com/watch?v=LtXmsxRdiUw
