What to do if you have an Ethernet application that is already up and running with TCP/IP functionality and now you want to add Wi-Fi. Most of the Wi-Fi modules available have embedded TCP/IP stacks with some kind of api interface you have to use (i.e. TCP_open(google.com, 80)). This is good if you are starting a fresh application and want to be able to quickly get something simple up and running.
But what if you already have a complex application with TCP/IP stack and you just want it to use Wi-Fi? You want to be able to take the raw Ethernet packets that are coming out of your TCP/IP stack and send them to the Wi-Fi module. I have found a few Wi-Fi modules that allow this "TCP/IP bypass" feature but not many.
To me it doesn't seem like that unique of an application and I wonder why it is not easier to find modules that allow this type of solution. What are others doing in this situation? i.e. - an existing TCP application where you'd like to "drop in" Wi-Fi
    \$\begingroup\$ You want a "bridge". Random example: silexamerica.com/products/connectivity-solutions/… \$\endgroup\$ – pjc50 Jan 22 '16 at 19:16
  • \$\begingroup\$ Then you want a real embedded operating system with a real TCP/IP stack, not one in which stacks are bolted into apps or walled-garden components. \$\endgroup\$ – Kaz Jan 22 '16 at 20:32
  • \$\begingroup\$ The bridge device looks nice. That would serve the purpose except that I want to integrate the solution. And end up with a device that has an Ethernet interface and a Wi-Fi interface. \$\endgroup\$ – ZooS Jan 25 '16 at 20:48
The modules that have the embedded TCP/IP stack all have a Cortex M3, M4 or similar processor to run the stack. You need a module without the processor, so you can use the stack on your existing processor. They are available, I'm using a Murata SN8000, partly because the drivers for Freescales Linux are available. These processor-less modules are cheaper and have better performance than the embedded processor versions.
  • \$\begingroup\$ So does it have a simple API? for example: scan_networks() //return list of wifi networks in the area; set_mac_address() //to set the mac address the module will use; send_raw_data() //send Ethernet packet; that kind of stuff? \$\endgroup\$ – ZooS Jan 25 '16 at 22:55
