I have a design that does not have enough vertical clearance for a standard RJ45 socket. I'm hoping to use a connector like this one from Molex.
I will use Cat5e cable when building my cable with the alternative plug.
The question I have is what considerations need to be made when doing this from an impedance, signal integrity, and EMC perspective? (especially at gigabit speeds)
  • \$\begingroup\$ There doesn't seem to be anything in the datasheet about the connectors impedance. Perhaps you ought to consider some low-profile connectors that are specifically designed for Gigabit ethernet. \$\endgroup\$
    – uint128_t
    Jan 23, 2016 at 1:18
  • \$\begingroup\$ It will probably work, and with the right tuning stubs on the PCB to compensate for the connector it might even work well. \$\endgroup\$ Jan 23, 2016 at 7:49
  • \$\begingroup\$ @uint128_t ... if only they existed. \$\endgroup\$
    – Funkyeah
    Jan 28, 2016 at 23:03
  • \$\begingroup\$ @Jasen I'm curious how you would tune a fully differential signal with stubs \$\endgroup\$
    – Funkyeah
    \$\begingroup\$ @funkyeah, i don't know how they do it either, but I see weird traces when I dissasemble the cat5E socket inserts. used in structured wiring. \$\endgroup\$ Jan 30, 2016 at 20:17
Here is my take: gigabit Ethernet is 125Mbaud, around 80MHz bandwidth, my guess of edge rate of a couple ns, edge travel distance of 1/3 of a meter. That should be a lot longer than the travel distance of the transition through the connector system. So the exact impedance does not matter that much.
Of course you want to avoid connectors with excessive capacitance and inductance. I think one way to check that is to measure the travel distance of the signal from the termination point at the PCB to the point where the cable unraveled. If that is shorter than the compliant RJ45 set up, then it is probably no worse than the RJ45 arrangement.
This also points out that when terminating the cable to the mating connector, it is necessary to control how much the cable get unraveled (un-twisted).
By the way, in the old days, PCB terminated RJ45 jacks almost always have the spring contacts on top (locking tap at the bottom). So the wire of a contact has to travel to the back of the jack and then down to the PCB. Now most jacks are flipped "upside down" so the traveling path becomes significantly shorter.
    \$\begingroup\$ Thought you might like to know why they were originally designed with the contacts on top: it was a dust issue. If the contacts were on the bottom, and nothing was plugged in for a while, dust could accumulate on the "floor" - where the contacts were. That dust could interfere with a cable when it was plugged in - or worse, be conductive and short something... \$\endgroup\$ Aug 28, 2016 at 11:43
