I have a single phase AC motor. I found it from Photocopy machine. That motor same to Fan motor. It has a capacitor to make phase angle. I don't know what is the correct name of my motor.
Can I change rotation direction of that motor?
edit:
This is the photo of my motor. enter image description here
  • 4
    \$\begingroup\$ Maybe. It sounds like an induction motor. Photo? Part number? You can see it. We can not. \$\endgroup\$
    – Transistor
    Jan 23, 2016 at 14:20
    \$\begingroup\$ Sounds like a split phase or capacitor run motor. \$\endgroup\$
    – KalleMP
    Jan 23, 2016 at 16:28
  • \$\begingroup\$ As I know It make a phase angle between current and voltage using It's capacitor.Lot of table fans,small water pumps has this type of motor. \$\endgroup\$
    – user_fs10
    Jan 25, 2016 at 15:09
    \$\begingroup\$ @KalleMP yes..its a split phase induction motor as describe in this link electrical4u.com/types-of-single-phase-induction-motor \$\endgroup\$
    – user_fs10
    Sep 21, 2016 at 14:03
    \$\begingroup\$ Can you post a photo of the motor's nameplate? \$\endgroup\$ Jan 7, 2017 at 15:50
If you have access to internal connections between the coils, you can reverse the motor by reversing the connection of one coil with respect to the other one.
  • \$\begingroup\$ This looks good. Sometimes if the motor is made to be reversible then both windings are the same rating and you can move the capacitor to the other winding. If it is a consumer motor that should only be used in one direction then the capacitor connected winding may be lower rating and you will have to follow the answer above to change the phasing. \$\endgroup\$
    – KalleMP
    Jan 23, 2016 at 16:30
  • \$\begingroup\$ This method is working properly.I change capacitor winding direction.It was a good way. But I cant agree with @KalleMP. Winding has different resistance. \$\endgroup\$
    – user_fs10
    Jan 25, 2016 at 15:04
  • \$\begingroup\$ It is true that the windings are sometimes identical, but it is not surprising that a fan motor from a copy machine would not be that kind of motor. \$\endgroup\$
    – user80875
    Jan 25, 2016 at 15:37
  • \$\begingroup\$ @NSiri My comment was exactly to warn you that the windings may be different if the motor was not intended for simple reversal. The linked image shows the simple connections required for a motor designed for reversing. wimb.net/sec_slosyn/img0/singlephaseconn.gif \$\endgroup\$
    – KalleMP
    Jan 28, 2016 at 7:56
  • \$\begingroup\$ If the windings are not identical, then it is quite probable that the motor won't have equivalent torque in the "opposite" direction than it was originally designed for. \$\endgroup\$ Jun 5, 2016 at 19:54
